BobbyD
John Wells has a great answer to "forgetting" that you left your turn signal on....... Here's the gist of the email he sent out and I got mine yesterday. Pictures below.
"<span style="font-style: italic">Hello to all who have enquired about the LED/bleeper/flasher upgrade in the past. I have just built some more TR 'indicator bleepers' if you are interested in one (or more!) The price is £15 each (+ £1 postage UK) (£2 overseas) for payment by PayPal to this email address ( jetstuff@dsl.pipex.com )Some cars do not have MES (screw in ) bulbs apparently (they have push-in or bayonet or some other type).I can supply MES (Minature Edison Screw) type only, or alternatively the existing bulb is removed and the two wires from the bleeper are connected across the bulbholder wiring with two 'Scotchloks' that I can supply instead of the bulb-base.....</span>"
The buzzer is piercing loud but can be toned down as much or as little as you want by just putting some tape over the sound hole. NFI.....but a very cool idea especially when you consider that you can also use it for the Oil warning light in which case a piercing sound is probably a good idea!
