If It's Not One Thing It's Another
jhorton3
Fuel pump stopped clicking today. Car was running for 5 minutes and then died. Made attempts to restart and realized the pump wasn't clicking. It's a low pressure square body Facet type. Here's what's strange. I left the car for an hour and tried to crank it again. The pump clicked for about 20 seconds and stopped. There's no fuel at the carbs and she's sitting with 3/4 tank of gas.
So the question is, mechanical failure in the pump or electrical? All wiring is in tact and the fuses are good. I've always been concerned about this pump as it is always pumping. It never slows when pressure builds up.
texas_bugeye
Not sure how yours is mounted but on mine its mounted at the rear bulk head at about the same height as the fuel oulet of the tank. i have it soft mounted using some 1/4 pices of fuel hose as the bushing. When the car has been sitting for a day or so, yes its a Weber not an SU, it will run loud for a few seconds until it fills the floatbowl then quite down to almost silent. I would check for flow out of the pump just prior to the fuel filter before you tear out the pump. This little fellas run forever. Also if there is any loose scale and such in the tank it could become trapped in the check valve of the fuelpump so as to not allow it to move the gas forward only back and forth in the pump.
jhorton3
jhorton3
Chris, you may be right. This is a relatively new tank so I wouldn't have thought I'd already have that much scale to cause this kind of problem. I put the rear of the car on jack stands and gave the pump a couple of good whacks with a rubber mallet. Turned the key and the pump ticked as it should. Fired the car up and it ran another 2-3 minutes before dying because the pump wasn't ticking. Gave the pump another couple of whacks, but it wouldn't come on again. Guess I'm looking at taking it off and seeing if I can clean it out.
get a bigger hammer?
j/k
mark
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
G One thing after another MG 30
jlaird One thing leads to another Spridgets 11
Sarastro If it ain't one dang thing, it's another... Spridgets 10
Randy Forbes One thing leads to another... Austin Healey 5
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
L TR6 Is there any such thing for a TR6 ? Triumph 9
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
J Funniest thing you found working on your car Austin Healey 32
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
T What do you think - good thing I pulled them? Triumph 6
T Wedge TR7/8 doing it's thing in this clip Triumph 3
T I think I did a dumb thing Spridgets 14
C turn signal bulb type thing Spridgets 4
P weird thing with midget clutch pedal Spridgets 3
smaceng Help me find the steering thing! Spridgets 7
jdubois Finally, this thing is starting to run ok! Triumph 7
D Ready to shoot the thing II--an Latest Spridgets 7
D Ready to shoot the thing! Long story please help! Spridgets 10
T It's a small thing, but WOW. Triumph 25
jlaird This may be just the thing for someone. Triumph 1
regularman The bad thing about having a high rear gear Spridgets 13
G What is this thing !?!?!?!?!?!? Spridgets 6
Sarastro Was this a smart thing to do? Other Cars 18
regularman Still trying to figure this overheating thing out. Spridgets 35
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
healeyboz Is there such a thing as Spridgets 4
T Hap, what is that thing...? MG 14
vping Last thing on my OD problems. MG 5
