One thing after another
Thanks Doc. Carla's home with her "good eyes" so we'll try to check it out. I just looked in the VB catalog thinking "maybe we should just replace the whole valve." OUCH!! $600.00...how can THAT be? :smile: Hopefully, that won't have to happen.
OK, here's the latest scoop. We can't see into the valve hole where the low pressure sensor switch lives but it feels like (using a toothpick) that we do have a valley. Disconnected the two lines out of the master cylinder and the brake pedal goes to the floor and squirts lots of fluid out the hole for front brakes but spits out air and a little fluid for the rear brakes. Does this mean just more bleeding in the rear or a master cylinder repair kit? If it's a repair kit, do we get parts for the main piston, etc. or the trap valve in the banjo fitting? HOPE we are narrowing it down. Many thanks.
Gary and Carla
Perhaps an air bell migrated to the MC... I'd be for reassembly and bleed it again.
And don't forget to "irrigate" the coachwork where any fluid has leaked. :wink:
Thanks Doc...We'll try the rebleeding before we go to reBUILDING!
A sure way to check the valve would be to test the switch outside the mechanism to see if it even works... ohm it in both positions. If it does function (open when in the "normal" or out position, closed when the pin is depressed). Reinstall it into the hole and ohm it again... If it is still open, the shuttlecock is centered.
HTH!
Thanks...we'll try that also.
RATS!!! Typed a long post and lightening apparently knocked me offline for a split second and it disappeared...trying again.
We have brakes again!! As we used to say when we were flying for a living "we must have had a short between the headsets." We were bleeding with a tube in a jar of brake fluid and THOUGHT that it was sealed on the nipple...not. When we went to the old "finger over the nipple" on pedal release they did their job. Whew...glad thats over and was simple even though stupidity struck AGAIN. I think it was JP who said that we might be overthinking the problem...you were so correct. Thanks guys. Now if we can just get the carbs, etc. tuned and sorted out we should have a running car.
Gary and Carla
Good news, indeed!!
A bit of a niggling point, the spring going behind the shoes on the bottom should have the part that is long and sticks thru the shoe to contact the e-brake actuator should be on the top of the link pushing down.
So Doc...is it that my spring is in the correct place but the tip of the spring should contact the top of the e-brake actuator? Or am I confused on your explaination?
You got it. Placement is correct. The spring end should be on top of the actuator.
Thanks...I'll try to fix that
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
jhorton3 If It's Not One Thing It's Another Spridgets 3
jlaird One thing leads to another Spridgets 11
Sarastro If it ain't one dang thing, it's another... Spridgets 10
Randy Forbes One thing leads to another... Austin Healey 5
mezy A thing of beauty Other British Cars 3
Hamish Racing 1963 original racing film British cars doing their thing Racing 0
K TR2/3/3A What is the little white fiber thing for that comes in the Lucas points box? Triumph 2
S TR2/3/3A What's a little thing that made a huge difference in your vehicle? Triumph 37
S TR4/4A What is this thing? Triumph 3
L TR6 Is there any such thing for a TR6 ? Triumph 9
Pythias For Sale The Red Thing... Make Offer.. Spridgets Classified 0
60TR3A What's The Weirdest Thing Anyone Ever Said or Asked You About Your Car? Austin Healey 28
J Funniest thing you found working on your car Austin Healey 32
AN5Sprite "Does this thing have airbags?" Spridgets 22
DrEntropy MGB A little thing MG 4
ObiRichKanobi These cars do the damnedest thing... Triumph 12
R Does this thing come off? Spridgets 5
Boink Tonneau Covers - that flappy thing - what is it? Spridgets 17
Mickey Richaud Just the Thing... Other British Cars 21
lbc_newbie Closest thing to a West Coast deal!! Spridgets 4
TR6oldtimer The thing I forgot to do Triumph 2
Brosky TR8 Visors NLA, so I did the next best thing Restoration & Tools 2
BobbyD TRafficator Signal LED Buzzer Thing Triumph 7
mikecyc72usa It's a good thing, right? MG 3
tinman58 Second thing to check Triumph 14
1 What is this thing? MG 10
TR4A_IRS TR4/4A TR4 Hardtop - Is there such a thing? Triumph 7
T Post-War Other No such thing as a 1 hour job on a Herald Triumph 8
pjsmetana Fuel Filter, anyone got a part # for this thing? Triumph 11
T What do you think - good thing I pulled them? Triumph 6
T Wedge TR7/8 doing it's thing in this clip Triumph 3
T I think I did a dumb thing Spridgets 14
C turn signal bulb type thing Spridgets 4
P weird thing with midget clutch pedal Spridgets 3
smaceng Help me find the steering thing! Spridgets 7
jdubois Finally, this thing is starting to run ok! Triumph 7
D Ready to shoot the thing II--an Latest Spridgets 7
D Ready to shoot the thing! Long story please help! Spridgets 10
T It's a small thing, but WOW. Triumph 25
jlaird This may be just the thing for someone. Triumph 1
regularman The bad thing about having a high rear gear Spridgets 13
G What is this thing !?!?!?!?!?!? Spridgets 6
Sarastro Was this a smart thing to do? Other Cars 18
regularman Still trying to figure this overheating thing out. Spridgets 35
Tinkerman Did a REAL Dumb Thing!!!! Triumph 7
healeyboz Is there such a thing as Spridgets 4
T Hap, what is that thing...? MG 14
vping Last thing on my OD problems. MG 5
