Motorcycle oil and old cars.
Deleted member 451
I was talking to a Redline oil distributor the other day about our old cars and the problem with modern oils not having enough zinc for the flat tappet cams. He said that Redline made oil specifically for these engines; it’s called ‘Heavy Duty Motorcycle Oil’. Harley still uses flat tappet cams in their engines and because motorcycles are exempt from pollution laws they can run the needed additives that cars can’t.
The only downside is that I’ve only found it in 20-60wt. I live in Florida so that’s not a problem here but it might be a little thick for the north.
Another issue is the price, $100 per case but that is a year’s supply for me and my car is worth it.
You may want to dig a bit deeper. We do not use car oil in motorcycles because most have wet clutch packs. This requires the formulation to be less slippery in order that the clutches grab. I've not done any research to see what that difference is, but you'd do well to find out I think, before making that switch.
I was going to post this but did not because I thought everyone had enough about oil but I will anyway.
I called a tech at Citgo a few days ago and explained our flat tappet/cam needs and lack of ZDDP problem with the new oil products.
He recommended CITGARD® 500 Engine Oil which comes in several weights. It is also a heavy duty motor oil and has .135 ZDDP which is a good level for our cars.
I have been finding that generally heavy duty oils recommended for both trucks and farm tractors and rated "CI-4" or "CI-4 Plus" have the additives we need. If in doubt about your choice of oil, it might be a good idea to call the oil company tech line.
I contacted Redline about the wet clutch friction modifiers that are in motorcycle oil. Acording to them there is no problems with running this in a car engine. They also said the additional additives for the cams would be an improvement over the regular car oil. They feel that their normal oil is better than the other regular oils on the market for these cams because they have higher than normal ZDDP levels.
Tom,
I not the kind of guy that worships or bad mouths any particular brand of oil but I have had really bad luck with CITGO oil in the past. Their 10W30 seems to really thin out when hot. I spun a main bearing several years ago on a Ford 302 and the oil analysis showed the oil viscosity was closer to 0W than what the bottle said.
Plus the fact that our friend Hugo Chavez runs the company is enough to make me stay away.
J Motorcycle oil for Mini, based on shared oil British Motor Corp 4
RAC68 Motorcycle Oil Castrol 4T 20W50 Any Information Austin Healey 15
K TR2/3/3A Castrol 20/50 Motorcycle Oil for TR3? Triumph 2
AngliaGT Black Lightning Motorcycle Cafe British Motorbikes 2
JPSmit Triumph [Motorcycle that is] Spotted 0
aeronca65t Motorcycle Hearse? British Motorbikes 8
JPSmit Motorcycle, likely BMW Spotted 2
aeronca65t 20th Century Motorcycle Shop British Motorbikes 1
Rhodyspit75 Triumph motorcycle British Motorbikes 2
PAUL161 General MG Where Would You Put This? MG , VW, Motorcycle? MG 3
aeronca65t Solvang Motorcycle Museum - Calif British Motorbikes 3
Patrick67BJ8 Magazine Ad with '66 Healey and Triumph Motorcycle Austin Healey 0
SilentUnicorn National Motorcycle Museum- UK British Motorbikes 1
aeronca65t Motorcycle Diaries British Motorbikes 0
S The Motorcycle Cannonball - 2010 British Motorbikes 7
SilentUnicorn How not to clean a motorcycle chain British Motorbikes 6
SilentUnicorn neat motorcycle website. British Motorbikes 3
SilentUnicorn Motorcycle Insurance British Motorbikes 9
N Norton Photo's over in British Motorcycle forum Triumph 1
58Custom Can adapt motorcycle mercury carb sync tool to SU? Spridgets 3
C TR6 Motorcycle carbs on a TR6 Picture Triumph 3
beaulieu Getting a good exhaust tone - motorcycle muffler? Racing 4
donbmw Motorcycle road races Racing 0
tony barnhill Motorcycle License British Motorbikes 9
Simon TR4a Motorcycle engine swaps British Motorbikes 1
T TR6 tr6 connecting rods/motorcycle connecting rods Triumph 2
A Anyone got a Sunbeam motorcycle ? Sunbeam (Rootes) 3
Webb Sledge Any Vintage Motorcycle Enthusiasts here? Triumph 12
T TR2/3/3A fuel pump oil leak Triumph 7
D T-Series MGTD Oil Leak? MG 2
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
Carlbanan56 MGB MGB oil consumption MG 5
1955TR2 TR2/3/3A TR2/3 Oil Leak Where Oil Sending Pipe Connects to the Block Triumph 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
af3683 TR2/3/3A Recommended Oil Filter Cartridge for Purolator Triumph 8
R oil pressure Spridgets 2
RickPA Overdrive Oil Pressure Austin Healey 8
6 Valve Oil Seals Spridgets 10
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
Lotuswins Dry Spin-On Oil Filter Austin Healey 14
Todd78d Oil Spridgets 6
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
G Right-Side Shock Weeping Oil Austin Healey 1
scottkilpatrick TR4/4A Gear oil and choke question Triumph 4
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
G High Oil Pressure Austin Healey 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
Bayless What oil for Datsun 5 speed? Spridgets 7
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
