TR6 tr6 connecting rods/motorcycle connecting rods
tr6lover
i was wondering if anybody had any knowledge of this, i think i read something about it a while back. i read some article that i think talked about replacing the connecting rods in a spitfire engine with motorcycle connecting rods. the spit con rods are the same as a tr6. anyone have any info? thanks
Randy
Simon TR4a
Nobody seems to be going for this so.....
I assume you are looking for a better replacement as stock rods are easily obtained.
Most modern bikes are multi-cylindered, so have very short strokes and tiny rods, so I assume the reference would be to some kind of large capacity dirt bike with a single cylinder engine, or a big v-twin. Even in this case most modern engines are high revving, with quite shoprt strokes, so to have a reasonable rod ratio, quite short rods.
Your best bet might be to check a source like Carillo,Manley or Pauter.
Simon.
G
You could try Prirace. The guy who runs it was into bikes before TRs according to his site. His conrods as shown are quite a bit cheaper than Carillo, but X cross-section rather than H.
You'd probably have to wait a few weeks for Carillos - I know that I did. There are other choices (Arrow for example - see RevingtonTR) but they cost even more.
AFAIK there isn't a magic swap - and I spent quite a bit of time looking. Unless you are going for crazy power the stock are good enough. I know this doesn't really answer your question, but I hope it's of some help.
tr6web TR6 TR6 Wiper Motor Connecting Rod Triumph 2
J For Sale Set of Dayton 72 spoke chrome wire wheels for TR6 / TR250 Triumph Classifieds 1
M TR6 TR6- Weber 3236 downdraft conversion Triumph 5
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
P TR6 Horn issue 1974 TR6 Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
R TR6 TR6 Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
A For Sale 1974 TR6 Triumph Classifieds 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
