Main / Rod bearing sizes.
Falkon
I'm in the proses of purchasing everything i need to put my engine back together, and iv ran into a problem.
I'm ready to buy the Rod bearings and the Main bearings for the engine. The only problem is i don't know which ones i need. There are four different types to choose from.
Standard
.010
.020
.030
I was thinking of getting the standard but I'm not gonna order until i know for sure.
So my question is.
How do i know which size i have and which size i should order.
P.S. Im buying from this site https://www.northwestimportparts.com/default.aspx
Good cheap prices compared to some things on Moss.
Haven't had a problem with them yet.
Look at the back of your old bearings. What you need depends on what you had in it; if the crank has been worked before.
Lemme guess, you took it all apart and threw away the old bearings, right?
Nope iv still got everything from when i took it apart. its all in plastic bags with labels so nothing get mixed up or lost. And the old bearings don't say anything about there size. iv looked all over them and haven't seen a single thing that indicates its size
They should have a pt# and 010, 020, 030 or 10, 20, 30. My factory ones didn't have anything and they were STD. What's the pt# off the back, got a pic? Google the pt# and you'll know.
looks like you need to measure the crank!
Maybe take it down to the local machine shop with the shop manual which lists the journal sizes, bring beer, and maybe, they will help you out!
Scott in CA
Main bearing VP 4691 other side AEG 158
Rod Bearing Vp 2783 Other side 2A 690
From what im reading i just need the standards.
From what I've read STD/STD but it's ALWAYS best to mic them to be sure. Hap should be along shortly and will be able to tell you if indeed these are STD.
B Rod & Main Bearings Recommendations Austin Healey 10
F Using 12 point ARP style rod and main bolts Spridgets 9
H Main and Rod Bearings Austin Healey 10
J Rear Main Seal Kit Austin Healey 1
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
D MGB 3 Main bearing 1800 & Moss Supercharger MG 1
algot1901 1950 Prefect/Anglia Trsnmission Main Bearing Retainer Other British Cars 2
S TR2/3/3A rear main seal is leaking Triumph 13
J RIB CASE MAIN SHAFT ASSEMBLY Spridgets 2
R Wanted 3 main crank MG Classifieds 1
R Wanted 3 main crankshaft MG Classifieds 0
J General TR Main bearing caps Triumph 6
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
D TR2/3/3A Main ground connection Triumph 2
R Main Bearing Cap Removal Austin Healey 12
S MGB early transmission vs od transmission for 3 main engine MG 5
D rear main seal Austin Healey 13
G TR4/4A And the fun continues...rear main leak Triumph 5
D BT7 main bearing seals Austin Healey 11
Michael Oritt 100 Main Bearing Caps--removal in situ Austin Healey 9
B General MG Solutions for topical MG rear main leak? MG 7
T BJ7 Slipping Clutch? rear main seal? Austin Healey 11
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
charleyf TR2/3/3A Center main cap engine Triumph 4
Joe Schlosser Bugeye Main Switch Spridgets 11
wkilleffer MGB 1974 MGB- New main wiring harness, but no start MG 13
Gerard 1098 10CC rear main seal conversion Spridgets 4
W A-40 Somerset - Leakage at Rear Main Bearing / Oil Seal Other British Cars 0
T General TR main bearing Triumph 9
Martinld123 Drain Pipe Rear Main Bearing Cap BN2, remove? Austin Healey 2
KVH General TR Rear Main Seal--Minor Problem Triumph 4
KVH General Tech Centering Real Main Seal Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
K TR2/3/3A Refresh...main reson why idle will lower when kicking the gas pedal? Triumph 3
KVH TR4/4A Real Main Seal and Pulling the Engine Triumph 19
Editor_Reid Rear Main Seal for BN2 Austin Healey 12
Gerard 1098 "10CC" rear main Spridgets 0
J BJ8 rear main seal kit - is it necessary and worth the risk to install? Austin Healey 33
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
S TR2/3/3A front main cap sticks proud Triumph 6
sim HUS 2 main jet adjustment Spridgets 40
C TR4/4A Rear main seal Triumph 36
S TR2/3/3A rear main seal Triumph 20
E 100 4 Does anyone recognize this rear main seal mod? Austin Healey 12
A 100 engine main bearing cap nut question Austin Healey 0
B Rover V-8 main bearings Rover / Land Rover 5
KVH TR4/4A Viton Rear Main Seal Triumph 12
oxford main bearing caps Austin Healey 4
C Rear Main Seal Leak with Moss Retrofit Austin Healey 21
