J-type overdrive question
TR3TR6
I have a TR6 j-type overdrive transmission out of the car that is leaking fluid from the gaskets. When I attempted to seperate the overdrive unit from the transmission to replace the gaskets, it would only seperate about an 1/2 inch. I'm sure something is engaged to keep it from coming apart. Has anyone run into this problem; if so, how did you solve it?
The Buckeye Triumphs web page has instructions on a J-type overdrive rebuild and they mention an issue that can cause binding (spline loading).
Buckeye Triumphs J-Type Overdrive Disassembly Instructions
Note that on reassembly they have the following comment as well.
"On the first attempt the OD wouldn't go in the last half inch or so indicating the splines were misaligned."
Scott
I just wanted to let you know that I did what was suggested in the Buckeye's website and it worked very well. Thanks for the help.
Terry :smirk:
Terry,
Glad to hear that it worked for you!
Scott
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
D A type overdrive question. Triumph 3
71tr J-type Overdrive Pressure Port Question Triumph 2
7 question after testing a J type overdrive Triumph 5
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
CinneaghTR A-type Overdrive Model Number Triumph 14
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
