Innocenti 1275 upgrade path
abarth69
Its been a while been a member since 2003 how time passes
Pulled my 1275 in my Italian Sprite last week and the lifters are a mess. After 7 years its time for a major rebuild going .040 bore and big head 1275 head 35,7 mm intake with a Piper BP 255 cam. Anyone use this cam ?
Cheers
Mark
can't offer any answers but will be watching with interest.
John Turney Anyone heard of an Innocenti Sprite? Spridgets 17
histerical '66 Innocenti Coupe Spridgets 3
S Innocenti Featured in Online Ad Spridgets 1
abarth69 Innocenti C Datsun 5 speed install Spridgets 21
L If you ever wanted an Innocenti... Spridgets 15
glemon I think it is an Innocenti Sprite Spridgets 6
JPSmit Innocenti for sale Spridgets 3
Sarastro Innocenti on eBay Spridgets 4
Mickey Richaud Innocenti on eBay Other British Cars 12
John Moore Innocenti Spridgets 11
BugEyeBear 65 Innocenti "S" Spyder for sale in Classifieds Spridgets 5
Sherlock Innocenti 950 Spider on E-Bay Spridgets 0
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
Rut Bugeye 1275 temp probe placement. Spridgets 8
jtaylor3 1275 EN40 Crank Spridgets 5
S 1275 Blueprints Spridgets 7
A Bugeye engine swap, 948 to 1275 Austin Healey 11
M Judson Supercharger On A 1275 Spridgets 6
6 Oil pressure, or lack there of on fresh 1275 Spridgets 13
H Is there any difference in using the 1275 Float Bowl that have a different casting? Spridgets 6
Jim_Gruber 1275 Crankcase capacity is? Spridgets 4
N 1275 cams? Spridgets 2
T matching 1275 to bugeye rad ?? Spridgets 12
T Wanted wanted-- 1275 ribcase shifter and shifter seat cover if possible Spridgets Classified 0
6 1275 Head to block dowel pins Spridgets 10
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
