TR2/3/3A Ignition points
RonR
Has anyone else experienced the problem of replacement points for a distributor not being able to close enough to achieve the required point gap?
Ron
CJD
Hey Ron....I haven't had that particular problem, but I have seen a lack of quality with many of the point sets that are out there. There are also differences between the early distributor points and the later, so perhaps you have a wrong set for your distributor??
R
RonR
Hi John.
The part number on the packaging was correct based on the Victoria British catalog.
It's interesting that "after market" points from both Moss and VB are $6.95 and $5.95 respectively. Lucas points from Moss are $32.95. VB does not offer Lucas points for the DM6 distributor, which is from an Austin-Healey 3000.
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
R Ignition points Austin Healey 21
RedTR3 TR2/3/3A Best Ignition points set? Triumph 4
Strapping_Lad Ignition woes... melted the points Spridgets 10
T Failed ignition points? Triumph 27
Bret UPDATE! Elect to Points Ignition woes? MG 15
martyc Small Spark at Ignition Points OK? MG 6
tahoe healey Ignition Points ["points closed"] Austin Healey 13
nevets Elan ignition points Lotus 4
R Ignition Failure Austin Healey 12
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
