Ignition conversion on 58 Bug Eye back to original
M
Mike
What would be needed to change my "turn and start" ignition back to the original 1958 Sprite ignition? Would I need to just change out the controls in the dash or would I also need a new starter? I'm not sure how the system works. Now it starts by just turning the key.
Thanks and Happy Holidays.
Mike
Sounds like you have a later ignition switch and a starter relay. Bugeyes had a pull switch for the starter; it's no problem to remove the relay (AKA starting solenoid) and install the pull switch. However, the bugeye ignition switch had the light switches built in, so you'd probably want to rewire that as well. I don't know what your car has done with the light switches. If they're separate from the ignition switch, you could leave them that way.
T MGB Vacuum advance and Electronic ignition conversion MG 5
rosalind electronic ignition conversion - advice please? British Motor Corp 3
Strapping_Lad Post Alternator conversion: Ignition light Spridgets 5
ObiRichKanobi Electronic Ignition Conversion Triumph 3
B TR6 TR6 Electronic Ignition Conversion Triumph 10
G TR2/3/3A Ignition Issues Triumph 5
D Ignition Timing Austin Healey 9
Bocaray TR2/3/3A 123Ignition Triumph 12
Ohiobugeye Can a Bugeye ignition switch be replaced with a universal ignition switch ? If so how would the wires be attached ? Spridgets 15
R Ignition Failure Austin Healey 24
R Bugeye ignition switch Spridgets 2
G Crane XR700 Electronic Ignition / BT7 Austin Healey 6
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
T 100 BN2 Possible Ignition Issue Austin Healey 10
Cokerair TR4/4A Fried Ignition Coil Triumph 18
R Wanted Bugeye ignition switch Spridgets Classified 2
J TR2/3/3A Red ignition light stays on Triumph 7
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
F Hot Ignition Coil Austin Healey 6
J Ignition Key Malfunction Austin Healey 6
R Electrical Experts - Vixen 2500 - Ignition Switch Observation? TVR 10
SherpaPilot TR6 Ignition Switch Question Triumph 13
PAUL161 T-Series MGTF Ignition Key MG 7
P TR2/3/3A ignition switch smoking Triumph 12
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
PAUL161 T-Series Points Triggering Electronic Ignition MG 5
W Healey BN1 Ignition Light Austin Healey 8
C TR6 Ignition Switch for 1972 TR6 Triumph 1
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
E Ignition Timing Austin Healey 14
T TR6 Continuous Starting and Ignition Issues Triumph 6
TRickster6 MGB electronic ignition on '73 MGB MG 1
K TR2/3/3A Ignition timing questions while I'm waiting for Spring Triumph 27
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
jlaird MGB ignition switch MG 2
algot1901 Electronic Ignition for 1950 Prefect 1172cc Eng Other British Cars 10
Lin Ignition timing question Spridgets 2
H MGB 1980 mgb no power from ignition switch MG 23
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Lin Crane or Fast XR700 Electronic Ignition Austin Healey 4
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
PAUL161 T-Series MGTF Xpeg Ignition Coil MG 22
M Tachometer not working following ignition upgrade Austin Healey 10
Cappy Ignition Warning Light Austin Healey 6
longbridgehealey Bugeye ignition switch Spridgets 4
J Ignition Key Cylinder Removal Austin Healey 3
G Inertia Cut-Off Switch - E-Fuel Pump to Ignition [Key] Switch Austin Healey 3
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
