Head gasket with four holes
2wrench
Yeah. I can't believe I didn't notice this. The head
gasket that was sent to me is for a four cylinder
engine.
Really a set back, because I have precious time that
could be used putting the thing together. Bummer.
Brosky
2W,
Did you buy a set, or individual gaskets? If you bought a set, I'd be checking the rest of them to make sure you didn't get a TR4 set.
2wrench
2wrench
I ordered two sets; one top end and one lower end.
I think the lower was cool. Used most of what was
there. The top end was for a four-banger. BP is
shipping a whole new top end set.
Brosky
I did the same, but had checked mine as soon as it arrived. The machinist wanted to mic the head gasket to be sure of the thickness and the thickness of the steel rings around each cylinder.
It takes a week for parts to get here from BPNW, so I checked everything as soon as it arrived.
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
T TR2/3/3A tr3 head gasket Triumph 38
DrEntropy MGB Head gasket R&R goes on... MG 13
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
R BJ8 Cylinder Head Gasket Austin Healey 38
B TR4/4A Head gasket won't lay flat Triumph 13
Michael Oritt Head gasket question Austin Healey 17
Got_All_4 General TR Payen brand head gasket sets what's the difference Triumph 10
Simmo TR2/3/3A Head Gasket Triumph 4
KVH General Tech Head Gasket Triumph 10
RJS General TR Head Gasket Test Fit Triumph 5
D TR2/3/3A head gasket... which way up?! Triumph 8
KVH TR4/4A Blown Head Gasket? Triumph 12
T TR4/4A Head gasket sealer question Triumph 7
T TR4/4A How to prep block to reinstall head for composite gasket Triumph 3
T TR4/4A Composite vs cooper head gasket with Randall's "trick" Triumph 6
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
H TR4/4A Head Gasket Issue Triumph 4
Got_All_4 TR2/3/3A What direction does the head gasket go? Triumph 4
T TR4/4A Best head gasket for a 4A? Triumph 12
DornTRoriginal TR2/3/3A TR3 Head Gasket Questions Con't Triumph 3
B Victoria British Head Gasket Austin Healey 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
G Payen XK engine head gasket -- which side is the top? Jaguar 2
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
S Recommendation on Head Gasket? Austin Healey 14
S Tolerance for head gasket Austin Healey 10
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
Gliderman8 TR6 Question on installing new head gasket Triumph 2
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
B Experience with Cometic Head Gasket for BN2? Austin Healey 8
S SaxMan's Cylinder Head Overhaul / Head Gasket Replacement Thread Spridgets 135
M TR2/3/3A Head gasket leaking in two places Triumph 13
S TR2/3/3A head gasket Triumph 5
AngliaGT General MG MGB GT Head Gasket - What do I need? MG 3
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
