Head Change????
nomad
Well, I hope this is the site for MGA info. Can anyone tell me if a 72 MGB "big valve" head will fit a 1600 mga without having to clearance the block for the valves???? Barneys site makes it sound like it might but not for sure so before I try I'd like confirmation. (Stock 72 head)
Kurt.
billspohn
I believe you can as long as you are using a stock camshaft. Anything else and the valves will certainly hit the block.
Drop the head on and hold it on by running a couple of nuts on. Put pushrods in one cylinder and bolt on the rocker shaft. Put a dial indicator on the back of each valve keeper in turn, and rotate the engine until that valve is fully open. Zero the indicator. Use a lever to push on the back of the keeper until the valve touches the head or piston. If it too less than .090" (remembering that the gasket will give you more margin) it is a 'no go'.
The big valve head is the only MGB head with a small enough chamber not to give you drastically low compression on a 1588 engine.
N
nomad
Thanks. Yes MGA guru mentions that head volumn needs to be about 38cc and that is the volumn of the 72 head so no head shaving necessary. I have a 72 head with hardened seats and my 1600 MGA head has at least one leaking exhaust valve plus major exhaust valve recession. If I simply run the valves to there most open position and lever them a bit more won't that be good enough? I can guestimate 90 thou pretty close. If too close then I will get technical.
Kurt.
5 BN4 cylinder head casting change date? Austin Healey 5
J First oil change after rebuilt and head torque Spridgets 6
PAUL161 Question on "B" head change. MG 16
J head change Jaguar 1
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
F TR2/3/3A head light buckets Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
R Big Healey 100 Head Austin Healey 4
R For Sale 100 engine block w/head Austin Healey Classifieds 3
B Surprise screw head Restoration & Tools 0
D TR6 Gp 2 cam, head shaved ,shorter pushrods, with a rough idle Triumph 10
K TR2/3/3A Who sells steering wheel control head "Allen head'' grub screws? Triumph 5
B Head Re-Torque Austin Healey 8
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
KVH General Tech Head Gasket Sealant Triumph 4
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
KVH General Tech ARP Head Studs/Liner Protrusion Triumph 10
healeynut For Sale 100/4 block and head Austin Healey Classifieds 1
