BN4 cylinder head casting change date?
5
57_BN4
Would anyone happen to know what the change date for the BN4 head casting was?
My car BN4O40559 came with an AEC271 head which has some cracking between the cooling passages and I have an AEC666 head off an A105 sedan which is in much better condition. I'm wondering what the car would have had originally.
The pics on Healeydata.com would suggest somewhere around BN4x30000 the head changed which would make the head which came with the car incorrect.
BN4L27518 AEC271
BN4L28224 AEC271
BN4LO29704AEC271
BN4LO29752 AEC271
BN4LO30601 AEC666
BN4L36686 -looks like AEC666 but hard to tell from pic
BN4O43177 AEC666
BN4LS48441 AEC666
BN4L48491 AEC666
The main visual difference between the castings is the addition of a brass blanking plug between cylinder 5&6 on top of the intake gallery.
dougie
The change was made on some cars starting in October of 1957 with BN4 - 48863 and all cars received the upgraded head by November 1957 with 52602.
57_BN4
Hi Dougie,
Thanks for the information. Are you referring to the separate-manifold head or the two versions of the gallery head? I'm just talking about the gallery heads only.
The workshop manual has drawings depicting both earlier and later gallery head for detailing different aspects of engine repair but it doesn't specifically identify one from the other or even mention any difference.
compare this pic with the one above, the brass hexagon plug at the back of the gallery is missing from this earlier head
Cheers,
Andy.
dougie
Yes, I'm referring to the introduction of the 6-port "MM" head. There is no documentation that I'm aware of that distinguishes between the differences in the early BN4's gallery head you've described.
57_BN4
Hi Dave,
Thanks, that agrees with the Healeydata information
Andy.
5 BN4 master cylinder caps Austin Healey 3
A 100/6 BN4 Restoration Austin Healey 8
A 100/6 BN4 Door Lock Austin Healey 15
zoohow BN4 Top Frame Installation Austin Healey 1
W BN4 Engine Mounts Austin Healey 2
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
P BN4 Generator Woes Austin Healey 7
W BN4 History Search Austin Healey 7
W Wanted Servo for BN4 has to be original 1957 or before any condition considered. Austin Healey Classifieds 11
W BN4 Steering box bushing. Austin Healey 2
Csarneson BN4 Windscreen Washer Jet Austin Healey 3
Hangtown Healey BN4 Front Springs Free Length Austin Healey 3
Csarneson BN4 Interior Assembly - Unidentified Holes Purpose Austin Healey 2
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
C 100/6 BN4 Soft Top Frame Austin Healey 16
A BN4 Hard Top Austin Healey 23
B Any experiences with adjustment of Jet Adjusting Nut on BN4? Austin Healey 5
B Side window question for early Longbridge BN4 Austin Healey 4
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
B Longbridge BN4 top frame question Austin Healey 6
K BN4 Locking Door Handle Removal Suggestions Austin Healey 10
B BN4 Longbridge door panel question Austin Healey 4
B Piping for Aluminum Shut Pillar Finisher on Longbridge BN4 Cars - Yes or No? Austin Healey 4
longbridgehealey BN4 Longbridge flasher unit. Austin Healey 19
longbridgehealey Removing BN4 Bonnet Austin Healey 9
John Turney BN4 to Early BJ8 Rear Axle Austin Healey 12
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
Csarneson Early BN4 steering box pitting Austin Healey 16
Csarneson BN4 Cam Gear Install Austin Healey 3
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
K Correct side screen nut for early 58 BN4 Austin Healey 14
D For Sale Detroit Locker Diff, Servo and Springs BN4 100/6 Austin Healey Classifieds 0
P BN4 Hesitates on Starting Austin Healey 12
Csarneson BN4 Wiring Questions Austin Healey 5
D Photos of Longbridge BN4 door seal track. Austin Healey 5
Bugeyze BN4 Windscreen Shims? Austin Healey 13
Csarneson BN4 Engine Rebuild Questions Austin Healey 8
G Wanted AH 100-6 BN4 Steering Wheel Austin Healey Classifieds 2
1 Price check on an original 1957 100-6 BN4? Austin Healey 29
C Price difference between 100-6 BN4 and BN6?? Austin Healey 14
L 100/6 BN4 Brake fluid Austin Healey 17
L 100/6 BN4 Hood fittings Austin Healey 5
MisterB Shut pillar differences? BN4 to BJ8 Austin Healey 7
L 100/6 BN4 Fuel Tank feed Austin Healey 5
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
T Dunlop 4 wheel Disc brakes on BN4 Austin Healey 11
busybrit Healey BN4/6 bell housing vs BN7/BT7 differences. Austin Healey 2
