Should there be any fien metail residue in the oil at the first oil change. While dropping the sump to fix dipstick oil problem I noticed some fine metal - not much in teh sump, is this normal. the cam lobes look ok and the cylinder bores looked ok from the bottom, i did not undo any bearing to check though.
and finally when torquing the head again, do i crack teh nut first or not?
