For Sale HD8 carbs and 2" intake
Zitch
I have a set of HD8 carbs and intake I'd like to sell...
They need a rebuild, comes with rebuild kits, intake and heat shield. (
$850 obo.
robertjr
Dont need the manifold as I will have one of my own to sell in a few months.. Am possibly interested in the two HD8 units. Will you separate? If so how much for the pair?
Zitch
Zitch
I basically gave them away... they were for sale for 3 months.
Here, Ebay,FB, AH forum... they were posted all over...
Rodknocker
Robert, I will remove them from manifold
Ed
wangdango Colortune for HD8 Carbs? Austin Healey 55
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
D Rebuilding the SU HD8 carbs Austin Healey 24
S Float Level for HD8, BJ8 carbs Austin Healey 9
D K&N filters for HD8 carbs Austin Healey 26
BOBBYR HD8 Carbs Austin Healey 2
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
A BJ8 SU HD8 carbs for sale Austin Healey 0
Lin HD8 carbs Austin Healey 2
M New Member with an HD8 Carb Question Austin Healey 1
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
B mysterious leaking of SU HD8 Jaguar 9
D S.U. HD8 Carburetor Drawing Austin Healey 6
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
pkmh HD8 SU Carburetor removal Austin Healey 48
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
