TR6 Fuel injection for TR6
ichthos
Hello,
I know this is a basic for many of you, but I would like to know the advantages and disadvantages of fuel injection - an option for this car. I have the opportunity to buy an original set, and I would also like to know what a fair price for the system would be. Also, I know there were different size pumps for this system. What would I need for a 69? Thanks,
Kevin
Advantages? About 50 more horsepower, good torque all the way up to redline, and of course bragging rights at your next club meet. Disadvantages? Parts only come from the UK, not that expensive but shipping can be costly. Its not rocket science, but it is alot different than carburation and needs to be treated with respect. Special equipment needed to set up metering units for your car. The horsepower advantages can not be realized without a proper cam, reworked head to UK specs.....the list goes on. Dont expect much change back from $1000.00 bucks, but if you are pretty handy then making up your own lines etc can save you some cash.
And as far as i know, there is only one pump for a PI system, the lucas pump. There is a mod to replace this with a Bosch pump which is a bit easier to obtain.
Good luck!
Mitch with a TR250/PI
To achieve the 150 hp you will have to duplicate the build of the earlier spec engines. The later build created 125 hp.
Bosch makes a fuel pump that many use as a replacement for the Lucas. Lucas pumps have a reputation of overheating.
Many people had horror stories about the PI systems, but I've also heard of many debunking the myth. I imagine the problem was PI were relatively rare and people were afraid to work on them. Much like people are afraid of SU's and ZS's.
I do know that a rebuilt PI system take a little time to "run in". The butterflies have to coke up before they seal well.
From what I understand, the fuel injection system put on the non-North American cars wasn't totally responsible for the 150 HP figure. The engine also had a pretty wild cam, and the compression ratio was higher. Because of the cam, there were lots of complaints about slow speed tractibility, so things were downgraded to 125 HP as mentioned above.
In all actuality, the 150 HP figure should be attainable with the Stromberg carbs if the cam and compression are changed. Maybe there were other differences, such as valve sizes etc., but I don't know.
The fuel injection was introduced in the hope that it would help in meeting the more stringent US emmission standards. It didn't work out as planned, so we in the US wound up with a de-tuned engine putting out no more power then the four cylinder TRactor motor it replaced. /ubbthreads/images/graemlins/hammer.gif
[ QUOTE ]
Hello,
Kevin
[/ QUOTE ]
Kevin, if indeed you have access to an original PI system and choose not to install it, I would be willing to bet that you can sell it to someone that wants those bragging rights.
And make a handsome profit doing it, depending on what you have to pay.
The conversion, as stated in above posts, ain't easy and ain't cheap. But someone will want it.
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
G TR6 TR6 Fuel Injection ? Triumph 8
Morris TR6 TR6 Fuel Injection Triumph 21
F TR6 RATCO fuel injection Triumph 4
6 General TR fuel injection Triumph 4
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
Feathers Fuel Injection Other British Cars 6
M Fuel Injection Austin Healey 51
rjc157 Patton fuel injection Austin Healey 0
rjc157 Fuel Injection Austin Healey 7
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
K 1977 924 Fuel Injection Other Cars 6
Coyote1 Fuel Injection System on Craigslist Triumph 24
JPSmit Fuel Injection for a B? MG 2
G Wedge TR8 Fuel Injection Triumph 7
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
AUSMHLY Youtube, 63 BJ7 with electronic fuel injection Austin Healey 28
S Fuel injection cleaning Triumph 6
newmexTR3 TR2/3/3A TR3 Fuel Injection / Turbo project Latest Triumph 12
DanNagy TBI Fuel Injection Installation Triumph 23
T TR6 TR-6 Fuel Injection Manifold Triumph 8
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
G Benefit of fuel injection Triumph 10
glemon 6 Cylinder Fuel Injection Conversion Triumph 22
Glen_B Bugeye Fuel Injection Spridgets 4
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
Sparkie Fuel Injection Help, please TVR 12
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
M Fuel injection system for Healeys now available! Austin Healey 20
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
SCguy Wedge TR8 fuel injection Triumph 5
kyreb1862 MGB MGB Fuel Injection? MG 13
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
H Healey Fuel Injection System Austin Healey 10
TRdynamo Fuel injection Triumph 6
aeronca65t Homebrew Fuel Injection Restoration & Tools 2
D Mini Fuel Injection British Motor Corp 11
Glennyboy MGB MGB Fuel Injection MG 5
H Fuel Injection on a Healey? Austin Healey 10
philip Carburetor or fuel injection? MG 7
W Fuel injection hose Restoration & Tools 2
MattP Fuel Injection Restoration & Tools 10
philman jetronics fuel injection Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
K Fuel Injection? MG 6
T TR2/3/3A fuel pump oil leak Triumph 7
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 25
