Fuel injection cleaning
sp53
Fuel injection cleaning products do they work? I mean how can you pour something into 15 gallons of gasoline and expect it do something to a fuel injector. I am asking because I find the knowledge on this forum the best. I trust you guys more than just about any shop or parts department.
I find when my Buick LaCrosse is sputtering and I add a bottle of injector cleaner, it does in fact run much better. I also get the same results if I run the next octane option at the pump. Seems to work for about a month and then I have to do it all over again.
About the only FI cleaner that is generally regarded as really working well is TECHRON by Chevron. I use it periodlically in all my cars...well, the ones that have fuel injection.
If you have injectors and you use a cheap gas. Please add a bottle at every oil change.
I was told several years ago that fuel injectors removed from motors that sat around for several months without being used would varnish up and miss or not work at all. The old mechanics trick is to soak those old varnished injectors in kerosen for 24 hours and that would clean them out. It worked for me several times, I've use this method for years. Good luck, Bill C, Mesa, Az
Redline's fuel injector cleaner and Techron are the only two worth buying.
If you want your fuel injectors cleaned, there are several companies that will rebuild them for about $15 a pop.
F TR6 RATCO fuel injection Triumph 4
hondo402000 TR6 TR6 Fuel Injection made easy Triumph 12
6 General TR fuel injection Triumph 4
J Austin Healey 3000 Fuel Injection and Supercharged Austin Healey 4
Feathers Fuel Injection Other British Cars 6
M Fuel Injection Austin Healey 51
rjc157 Patton fuel injection Austin Healey 0
rjc157 Fuel Injection Austin Healey 7
S Wedge TR7 Fuel injection problem Triumph 3
Got_All_4 Wedge 1980 TR7 Fuel injection questions Triumph 17
K 1977 924 Fuel Injection Other Cars 6
Coyote1 Fuel Injection System on Craigslist Triumph 24
JPSmit Fuel Injection for a B? MG 2
G Wedge TR8 Fuel Injection Triumph 7
G TR6 TR6 Fuel Injection ? Triumph 8
M Fuel Injection Problem on 87 XJ6 with 188,000 mile Jaguar 1
AUSMHLY Youtube, 63 BJ7 with electronic fuel injection Austin Healey 28
newmexTR3 TR2/3/3A TR3 Fuel Injection / Turbo project Latest Triumph 12
DanNagy TBI Fuel Injection Installation Triumph 23
T TR6 TR-6 Fuel Injection Manifold Triumph 8
PAUL161 MGB Fuel injection for MGBs. Added Photo MG 9
G Benefit of fuel injection Triumph 10
glemon 6 Cylinder Fuel Injection Conversion Triumph 22
Glen_B Bugeye Fuel Injection Spridgets 4
mgb4tim Wedge TR7 Fuel Injection/Charging system help. Triumph 2
Sparkie Fuel Injection Help, please TVR 12
B Range Rover Electronic Fuel Injection Rover / Land Rover 0
M Fuel injection system for Healeys now available! Austin Healey 20
mgb4tim Wedge TR7 Fuel Injection Pictures Triumph 1
SCguy Wedge TR8 fuel injection Triumph 5
I TR6 Fuel injection for TR6 Triumph 4
kyreb1862 MGB MGB Fuel Injection? MG 13
TR_Jim MGB MGB Electronic Fuel Injection System MG 15
aeronca65t MGB Fuel Injection-MGB-homebuilt MG 5
H Healey Fuel Injection System Austin Healey 10
TRdynamo Fuel injection Triumph 6
Morris TR6 TR6 Fuel Injection Triumph 21
aeronca65t Homebrew Fuel Injection Restoration & Tools 2
D Mini Fuel Injection British Motor Corp 11
Glennyboy MGB MGB Fuel Injection MG 5
H Fuel Injection on a Healey? Austin Healey 10
philip Carburetor or fuel injection? MG 7
W Fuel injection hose Restoration & Tools 2
MattP Fuel Injection Restoration & Tools 10
philman jetronics fuel injection Triumph 2
J XJ6 SII Fuel Injection- Convert to carbs or rebuild? Jaguar 6
K Fuel Injection? MG 6
T TR2/3/3A fuel pump oil leak Triumph 7
M MGB Fuel pump Banjo fittings MG 1
kodanja TR2/3/3A 1960 TR3A w/TR4 engine, fuel pump replacement Triumph 24
