TR6 End Float
Jerryny
Morning all,
I measured the end float on my 73 TR6. I'm using Dial test Indicator and have it positioned against the fan extender. I measured it a couple of times and I am getting 11-12 mm.
If I did the math correctly that comes out to .4". Sounds like the thrust washers may be worn. Did I do everything right? When I watch it move while the wife pushes the clutch I don't see it moving that much. Hmmm I must be doing something wrong
Are you sure you aren't getting .11mm to .12mm. Your gauge looks like it goes from .01 to 10mm. So I think your reading is .11mm to .12mm (.0043" - .0047").
I don't think it would be possible to have 11-12mm of crankshaft endplay.
The Bentley book say float @ 0.006 0.008 ( 0.1524 0.2032 mm ) A rule of thumb starting car with clutch out in neutral cuts down on wear on dry bearings and thrust washers. Madflyer
Good advice. When I changed out my thrust washers a few years ago, they were hardly worn. I always start in neutral.
Hope I'm not hijacking the topic, but reminds me of three issues I have. When replacing thrust washers, do you always replace both at the same time? Second, I have a bunch of spares and I'm worried I mixed them with two used ones from my last rebuild. I can't recall why, but I know I kept them. Can I rely on micrometer measurements to be sure I'm not wasting any time with my old ones? Finally, when you lightly oil-sand or buff them to reach end-float spec which side do you work on, or not work on? I guess I've got another--why is there a copper color side and an aluminum color side to the thrust washers? I'm getting rusty on all this. Been away too long.
I use a dial micrometer to measure the thickness of a TW..That's one of the measurements I use to determine the thickness I'll need for replacements oversized or standard 0.092"+/- .0005". The other measurement needed is the current endfloat with the old ones still in place. A feeler gauge between the old TW and engine block works just fine
Between those two you can figure what it'll take to get the endfloat... be that within the book specs or whatever you think best.
I would not go sanding on the TW's unless you're really scrapped for dough though....
Here's what I recommend:
http://www.customthrustwashers.com/
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
R TR2/3/3A Establishing distributor shaft end float Triumph 4
R Front wheel bearing - end float Austin Healey 40
KVH General Tech Distributor Gear End Float Triumph 6
J TR4/4A Transmission counter shaft end float. Triumph 3
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
Q "A" Type Overdrive Annulus End Float!! Triumph 4
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
Gliderman8 Crankshaft end float???? Triumph 30
T TR2/3/3A TR3 axle end float Triumph 5
bigjones Distributor end float Spridgets 14
K TR2/3/3A TR3 Front end..wishbone assembly end float??? Triumph 2
Sarastro Camshaft installation/end float problem Spridgets 16
T Cam shaft end float Triumph 18
KVH Distributor Drive End Float Triumph 6
N Spitfire Spitfire 1500 distributor end float? Triumph 2
Dug Crank shaft end float question Spridgets 3
P steering box end float Triumph 3
Bruce_B Measuring Crankshaft end-float questions? Spridgets 20
White79MGB TR2/3/3A TR3 Rear Axle end float setting Triumph 7
S Adjusting End Float Austin Healey 24
RobT 10 Thou End Float - Should I Worry Yet? Triumph 6
S End Float - Overdrive Tailshaft Austin Healey 2
D Mainshaft 3rd gear end float MG 0
M Layshaft End Play Austin Healey 7
M T-Series MG TD 1st/2nd sliding hub end play MG 1
D ARP big end bolts. Spridgets 7
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B MGB Mgb crankshaft end play shims MG 2
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Bent frame rails near BE front end Spridgets 2
S Rear End Noises Spridgets 28
Walter74 Steering Box End Play Austin Healey 2
S Sway Bar End Links Austin Healey 15
K TR2/3/3A Removal of tie rod end? Triumph 7
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
B 2013 Nissan Frontier front end mystery Other Cars 7
Jayplum TR2/3/3A Steering Box end play Triumph 6
J TR6 Top End Chatter Triumph 11
A TR2/3/3A Rear end locked up Triumph 6
drooartz MGB Talk to me about bottom end bearings MG 34
B BJ7 back end rebuild Austin Healey 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
