End Float - Overdrive Tailshaft
sawdust
I am rebuilding an overdrive unit( all new thrust washers and bearings, springs, pistons as well as the modified valve spring to boost pressure) for my 58 BN4. After getting it all put together for bench testing it appears to be in a bind, especially at the tailshaft end where it seems to be heating up. The best thoughts at the NTAHC is that the end float is incorrect either at the tailshaft or the sun wheel. Determining the correct spacer at the tailshaft calls for a special tool. Is there a way to accomplish this measurement without the tool, or does anyone have the specs for the tool so I can get one made? Using an electric motor designed by the NTAHC for the purpose of checking OD units, everything operated with the trans in neutral and in gear, although when we had it in 3rd that is when we started to notice heat build up at the tailshaft end. The pressure gauge showed plenty of pressure but when we manually activated the OD lever it basically stalled the electric motor.I'm search for suggestions as to what may be causing the problem as well as how to properly measure the tailshaft end float.
Hi Sawdust,
Welcome to a great forum.
There are several things that could be binding. I certainly wouldn't run it any more until the problem is solved.
I have a copy of the definitive how to for the type A OD, written by Nelson Riedel & published on "Buckeye Triumphs" before he pulled the article. It discusses how to set end float without the "tools" & a whole lot more.
Give me an email rusd@velocitus.net & maybe I can help.
Regards,
Q "A" Type Overdrive Annulus End Float!! Triumph 4
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
R TR2/3/3A Establishing distributor shaft end float Triumph 4
R Front wheel bearing - end float Austin Healey 40
KVH General Tech Distributor Gear End Float Triumph 6
J TR4/4A Transmission counter shaft end float. Triumph 3
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
kurts100 TR6 TR6 Trunnion/Lower A-Arm Bolt--Torque or End Float Triumph 8
Gliderman8 Crankshaft end float???? Triumph 30
T TR2/3/3A TR3 axle end float Triumph 5
bigjones Distributor end float Spridgets 14
K TR2/3/3A TR3 Front end..wishbone assembly end float??? Triumph 2
Sarastro Camshaft installation/end float problem Spridgets 16
T Cam shaft end float Triumph 18
KVH Distributor Drive End Float Triumph 6
N Spitfire Spitfire 1500 distributor end float? Triumph 2
Dug Crank shaft end float question Spridgets 3
P steering box end float Triumph 3
Bruce_B Measuring Crankshaft end-float questions? Spridgets 20
White79MGB TR2/3/3A TR3 Rear Axle end float setting Triumph 7
S Adjusting End Float Austin Healey 24
RobT 10 Thou End Float - Should I Worry Yet? Triumph 6
D Mainshaft 3rd gear end float MG 0
M Layshaft End Play Austin Healey 7
M T-Series MG TD 1st/2nd sliding hub end play MG 1
D ARP big end bolts. Spridgets 7
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
G MGB '71 MGB Front End Rebuild MG 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B MGB Mgb crankshaft end play shims MG 2
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Bent frame rails near BE front end Spridgets 2
S Rear End Noises Spridgets 28
Walter74 Steering Box End Play Austin Healey 2
S Sway Bar End Links Austin Healey 15
K TR2/3/3A Removal of tie rod end? Triumph 7
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
B 2013 Nissan Frontier front end mystery Other Cars 7
Jayplum TR2/3/3A Steering Box end play Triumph 6
J TR6 Top End Chatter Triumph 11
A TR2/3/3A Rear end locked up Triumph 6
drooartz MGB Talk to me about bottom end bearings MG 34
B BJ7 back end rebuild Austin Healey 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
