TR6 Top End Chatter
JWDH
I have a 75 TR 6 and I am wondering how much chatter from the valve train is OK. Mine I think is a bit noisy. When doing the head job it seemed that it was some what dry up there but I really have nothing to compare it to. which is causing me concern. Any thoughts out there about this.
poolboy
It's OK to remove the valve cover and let the engine idle...you won't get oil splattering everywhere, but you should see oil dripping from each and every rocker arm....maybe a drop or two a second once the rocker shaft fills up
Madflyer
If you have the stock cam valve adjustment may be lose as to more performance cams adjustments. oil at head important add oil line to head there is a kit and plug at the back of the head just for that reason. added oil to head does two things, lub of course and extra oil as cooling also. The stock valve cover is a can as to a alum. cover could make a differents also. I have both line and alum cover and hot cam.
Madflyer
J
JWDH
I have had the valve cover off and it has plenty of oil but after setting the clearance three times there seems to be to much clearance. I am wondering if this could be caused by worn rocker surfaces? I think this is the problem. Can I resurface the wear points or must I replace them? Probably replacing them is the best thing to do but I like pushing things.
J
JWDH
I have set the value clearance to 10000 of an inch three different times thinking I must be making an error somehow. With the feeler gauge I set it so it has a little drag and then tighten the lock nut. I then recheck to confirm accuracy. With the feeler gauge it is say tight. But, if I physically move the rocker back and forth I can feel movement. More than I think is 10000". I am thinking my rockers are concave. Am I wrong? Is it possible? Too much noise but runs fine.
poolboy
For the stock cams, the book says .010" = 1/100 of an inch
J
JWDH
So I put down the wrong fraction. The setting is correct one as per the manual and feeler gauge. But it is still loose. So is it possible that the rocker is worn in a concave?
charlie74
Yes, they can develop a depression where the rocker arm contacts the valve stem. I modified my 10thou feeler gauge so it is narrow at the tip just because of this.
poolboy
I'd have a close look at the contact patch between the valve stem and the tip of the rocker arm...See if there is a solid and even contact between the surface of the two.
The engine's valve train sounds similar to sewing machine at what's sometimes called 'tickover'
Madflyer
If your rocker to shaft are OK and your rocker shaft is not worn to much rockers can be ground smooth again but as they are cast and harden at tip best changed with new shaft also. Intake and Ex are different so 6 of each. Valves are much harder so best left alone. 0.010 was that cold ?? Madflyer
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
R Top end engine tapping Austin Healey 5
tosoutherncars 1500 top-end rebuild Triumph 22
tosoutherncars 1500 top end refresh Spridgets 4
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Bayless How does '67 Sprite top attach to body? Spridgets 3
D Top Door rubber and fuzzy seal Spridgets 5
Popeye TR4/4A Door seal channel near top of windscreen Triumph 6
Donald1107 TR2/3/3A Soft top Triumph 14
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
luke44 TR2/3/3A Tr3 top - corner fastener Triumph 4
N MGB Convertible Top Frames MG 7
roscoe New / old hard top Austin Healey 16
nevets BN6 Soft Top Webbing Austin Healey 2
R BUGEYE SOFT TOP FIT Spridgets 2
AngliaGT For Sale Two Piece Top Frame - MGB '62 - '70 MG Classifieds 0
57 Healey For Sale Original top (hood) frame for BT7 Austin Healey Classifieds 8
M Wanted TRIUMPH TR3A Hard Top Triumph Classifieds 14
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
D Wanted Wanted 80Spitfire hard top and seats Triumph Classifieds 0
EWD TR6 Top Install Triumph 3
B TR2/3/3A Hard Top Part Triumph 2
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
HealeyRick BJ7/8 Convertible Top Issues Austin Healey 5
JamesD BJ8 Top Frame Bumpers Austin Healey 12
