Do you have a picture of these convertible top details?
Little1
A prior owner has mostly installed a new vinyl top on my 1975 Midget 1500. There are three details I need to address and would be grateful for a picture or description of how these should go. Pictures attached.
1. A flap of vinyl at the front outer corner of the top where it meets the windshield. How should this be addressed?
2. The straps around the top frame where the top meets the door pillar. I imagine a snap here, or rivet. How tight should the strap be?
3. A strap that snaps to the frame at the top rear corner of the door window. How tight should the strap be, so I can position a snap in the vinyl?
Thank you all!
JPSmit
don't know about the first pic but the next two don't need to be terribly tight - I will try to get a pic or two up tomorrow.
L
Little1
Research indicates the first pic is due to the top not being forward enough on the frame. Prior owner started the install and quit part way. He put some of the side snaps in the wrong spots too. I've disassembled it and am redoing it so it will fit better.
JPSmit
and I realize I haven't posted pics - sorry - tomorrow!
JPSmit
My apologies for forgetting AGAIN! I took the pics but never posted them.
This is the one at the top (pic three of yours) I hooked my finger behind to give an idea of the amount of slack. It isn't that tight
the one at the back I took three pics of - when my top came the strap had the snap but it wasn;t long enough to reach so I made a little extension.
1. Snapped up
2. unsnapped
3. the extension bit I made
Hope it makes some kind of sense.
good luck!
K TR2/3/3A Picture of the Zinc washer. Triumph 3
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
lram59 TR4/4A What's wrong with this picture? Triumph 4
T TR2/3/3A Wanted - Picture of TR3A original firewall layout Triumph 5
steveg Picture needed - front turn light Austin Healey 4
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S TR4/4A Identify piece with a picture Triumph 7
steveg Great AH picture gallery Austin Healey 1
maxwedge5281 Driving Lights [picture posting opportunity!] Austin Healey 25
Marvin Gruber Need a picture please! Austin Healey 8
HealeyRick Sprite Factory Picture Spridgets 3
Marvin Gruber BJ8 brake booster picture Austin Healey 4
C Overdrive throttle switch rod connection picture Austin Healey 3
C Hub Puller...need picture Please! Austin Healey 4
S Your picture on road to Le Mans & Le Mans classic Spotted 8
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
Elva164 2014 VRG Turkey Bowl Video/Picture Thread! Racing 4
M General TR Restoration done, Picture time Triumph 33
P Bugeye front drum brake picture Spridgets 7
J Rocker valve assembly picture Austin Healey 6
Elva164 2014 PVGP Video/Picture Thread! Racing 32
luke44 General TR Every TR Owner should really appreciate this picture. Any guesses? Triumph 7
thechileman TR4/4A Cool Picture.. Triumph 6
J Picture of temp gauge , Austin Mini British Motor Corp 2
D TR6 "big picture" engine diagram? Triumph 2
R Need picture [s] of a BN7 or BT7 Servo installation Austin Healey 3
Brinkerhoff TR2/3/3A TR3A steering column grommet - picture? Triumph 2
drooartz First picture of the family mini-fleet Spridgets 12
J TR2/3/3A Picture of painted substructure, finally! Triumph 8
G `Request for Overdrive Speemometer Cable Routing Picture Triumph 0
M TR2/3/3A TR3 heater install picture needed Triumph 33
J Need a picture of how the transmission mounts to the frame. Triumph 3
John Turney Another picture question FORUM Navigation Questions 0
Tinkerman TR 3 Picture HELP Needed Triumph 5
CJD Picture of an early widescreen frame Triumph 28
P TR6 What happened to my TR6 picture? Triumph 1
mgedit Wedge Wedge Style Sidescreen ... Picture Request Triumph 8
HEALEYJAG cam specs for 100, 100-M.....bracket picture 100-M Austin Healey 8
dklawson Post-War Other Picture Needed - Herald and/or Vitesse Speedometer Triumph 8
B MGB anyone have a good picture of a 78 MGB dashboard? MG 2
M T-Series Looking for a picture of my MG-TF V8 form the sixt MG 1
B Second picture. I don't quite get this yet Triumph 1
S Old [for me] picture Spridgets 9
R posting a picture FORUM Navigation Questions 3
richberman picture of radiator side shields anyone? Austin Healey 10
N Picture series BJ8 distributor and carburettors Austin Healey 3
wangdango Bonnet striker plate detail picture/advice? Austin Healey 0
JPSmit Cool Picture thread Spridgets 57
H Picture of an original choke knob BJ7 anyone? Austin Healey 16
J rear shock picture; Surely this can't be right? Spridgets 8
