Layshaft End Play
McI
Hello to members, hope I'm in the right place. I'm hoping someone can suggest a fix for my transmission issues.
I'm currently rebuilding the gearbox in my '55 Healey and it seems to be in reasonably good shape except it has too much end play in the layshaft. The manual calls for .001" to .003", and I have .012". The fix was thicker thrust plates, but apparently those are now unpbtainable. There are bronze plates for newer models available from Denis Welch, and I have read of people making and modifying new ones, but mine seem to be hardened steel and I'm not set up for heat-treating.
I could just add a .010" ring of shim stock, but this doesn't seem like the place for that.
I also plan to replace the bearings as they have some small play between the races, and wondered about replacing the synchro rings. AH Spares sells rings that just press in. I wonder if anyone had thoughts re: these rings versus the ones that must be machined.
The bushings appear to be good throughout. I can get no play in any of them. The synchros appear to be almost undamaged, but it seems this might be a good time to replace them while I have the thing apart.
I would appreciate any thoughts people may have. Thanks!
Healey Nut
The thrust washers are available from AH spares and AH4H . You may have to lap one of them to suit what you need for end float . I just rebuilt my gearbox and went through this process .
Look for wear on the three lugs of the baulk rings and flattening of the interior ridges .
M
McI
Thnx for your reply, Healey Nut-my car has the 3 speed and at Moss they're all NA and AH Spares doesn't even have an item number. Bn2 and up seem to be available but not mine. I don't know of AH4H. I guess I was hoping I could adapt thrust plates from another model.
Healey Nut
This is screenshot right off Ahead4Healeys site in the UK
you could also contact Autofarm in Canada , they have a lot of good used parts .
Healey Nut
M
McI
I have been advised that 0.009" wear, though out of spec is not uncommon wear, and I could just reassemble the box and drive it. I am trending this way, just replace the bearings and drive as is. My other plan was to make one, which I don't see a problem with but am not sure what material to use-heat treatable tool steel of some sort. Since i'm in the middle of a frame-up resto it makes sense to get it running and revisit problems as they arise on the road. I don't have a problem pulling the transmission back out, since I'm retired-what else am I doin'?
Side mirror
McI, I also began a frame-up resto in October. While the frame/tub is getting de-rusted out of the garage, I have taken apart the gearbox. The layhaft end float is a tight .010 and slippery .009. I, too, am debating reassembling since the manual lists .012. I read from the forms that .005 to .012 is good and that .012 is the outside limit. I think .005 is tight, considering the heavy loads and heat that the transmission experiences.
Are you going to work on your OD unit? If so, please keep me posted. Rusty Beauties has some helpful YouTube videos on TR4 gearbox and OD unit.
M
McI
Hello Side mirror! Cheers and good luck with your resto. It sounds like our gearboxes are differnet-I have a bn1 3 speed, with layshaft endplay tolerance of .001-.003 per the shop manual. I'm opening and checking everything since this is a barn find and pretty much everything is dry or seized (there was a mouse living in the #3 combustion chamber), and making everything factory tolerance if I can. It sounds like you're within tolerance but I'm out .010. so I'm hoping to improve that.
Regarding the OD, I pretty much just did the inspection items per the manual and I was lucky, I had very little wear except the pump cam, which I replaced, and the clutch springs which were sacked a little bit. Probably would've been ok but they were cheap and available. It's gonna be awhile before I'm on the road but I'll try to keep you posted.
J MGA Layshaft bearings MG 3
5 Replacement layshaft Austin Healey 1
M Layshaft thrust washer dimensions MG 1
M T-Series MG TD 1st/2nd sliding hub end play MG 1
D ARP big end bolts. Spridgets 7
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
G MGB '71 MGB Front End Rebuild MG 2
AUSMHLY Synchromesh Hub End Float Austin Healey 1
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
X Front End Alignment Austin Healey 14
craigshealey3000 Front End Shake Austin Healey 31
B MGB Mgb crankshaft end play shims MG 2
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
B Bent frame rails near BE front end Spridgets 2
S Rear End Noises Spridgets 28
Walter74 Steering Box End Play Austin Healey 2
S Sway Bar End Links Austin Healey 15
K TR2/3/3A Removal of tie rod end? Triumph 7
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
B 2013 Nissan Frontier front end mystery Other Cars 7
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
J TR6 End Float Triumph 5
Jayplum TR2/3/3A Steering Box end play Triumph 6
J TR6 Top End Chatter Triumph 11
A TR2/3/3A Rear end locked up Triumph 6
drooartz MGB Talk to me about bottom end bearings MG 34
B BJ7 back end rebuild Austin Healey 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
R Connecting Rod Big End Specification Austin Healey 4
Michael Oritt Lube points on BN/BT7 front end Austin Healey 4
K TR2/3/3A Advise on previously botched front end lower fulcrum support bracket. Triumph 5
AUSMHLY BJ8 Front End Squeak Austin Healey 25
AUSMHLY 64 front end too high Austin Healey 14
John_Mc TR6 Twitchy rear end Triumph 18
T TR5/TR250 Wiper wheel box knurled end not tight on arm Triumph 9
J TR2/3/3A Hastings Piston Ring End Gap Issue Triumph 16
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Rut TR4/4A Rear end questions Triumph 8
R TR2/3/3A Establishing distributor shaft end float Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
thibault BJ8 plus 55mph Front end shaking Austin Healey 100
vette Effects of Lowering the Front End Austin Healey 21
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
G Front end Alignment - Total Toe vs. Individual Toe Austin Healey 3
