MGA Layshaft bearings
John_Progess
I need to install a new lay shaft in my MGA tranny and was wondering if there has been any problems with the new caged roller bearings that only have half as many rollers as original. Your thoughts are appreciated. Thanks and have a good day!
John
Platinum
That transmission is almost identical internally to the MGB early three-synchro one. We've put the caged layshaft bearings in a few of those. So-far, no issues with them.
ShawnC_at_Moss
John,
You have asked your question at a very opportune time. We will be releasing OE rollers for the MGA/Early MGB as early as today. We will offer the rollers with a more appropriate kit with distance tube and I believe circlips.
I am attaching a link to an Informational Document that will be posted when the kits are released. Today we have 25 kits on hand but no rollers by themselves as we used our initial supply in the kits which should be the popular option.
Hope this helps you in your search. If you wish to order you can give our sales team a call. I don't think these are on the web, yet.
https://www.mossmotors.com/graphics/products/instructions/461-868_INST.pdf
Happy Motoring,
Shawn
Platinum
Thanks, Shawn!
M Layshaft End Play Austin Healey 7
5 Replacement layshaft Austin Healey 1
M Layshaft thrust washer dimensions MG 1
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz MGB Any risk rolling car on dry bearings MG 4
B Rod & Main Bearings Recommendations Austin Healey 10
KVH General Tech Connecting Rod Bearings Triumph 8
Lin Bugeye Axle Hub & Bearings Austin Healey 1
Donald1107 TR2/3/3A Wheel bearings Triumph 8
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
C Seat Slide Bearings Austin Healey 3
algot1901 HELP with wheel bearings Other British Cars 1
Z 3000 Front Wheel Bearings Austin Healey 3
B Installing cam bearings 1275, can I do it? Spridgets 1
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
4tecdog Trunion bearings Austin Healey 5
Y MK V rod bearings Jaguar 1
drooartz MGB Talk to me about bottom end bearings MG 34
B TR4/4A Original gearbox bearings Triumph 14
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
M Wanted TR3/4 Cam Bearings Triumph Classifieds 1
FlyingCat Spitfire Wheel Bearings Triumph 3
Got_All_4 TR6 What engine bearings to use in my rebuild? Triumph 9
Bantamfan Bearings Spridgets 16
D cam bearings Austin Healey 23
R General Tech Wheel bearings Triumph 3
R Wheel bearings Austin Healey 5
T Differential Pinion Bearings Austin Healey 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
KVH General Tech Plasti-Gauge on Rod Bearings Triumph 13
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
Jim_Gruber New MOSS Tapered Front Wheel Bearings - WTH are the instructions Spridgets 16
N Wheel bearings?? Spridgets 4
Healey Nut Muffler bearings Austin Healey 5
R Rear Hubs/bearings Austin Healey 25
KVH General Tech Lubricating New Rod Bearings Triumph 7
N Front wheel bearings?? Spridgets 8
K TR2/3/3A Steering box bearings? Triumph 2
T TR4/4A Question on countershaft gear roller bearings Triumph 4
Don_R TR2/3/3A Rear Axle bearings Triumph 3
R BJ7 Seat rail bearings Austin Healey 3
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
KVH General Tech Are These Cam Bearings OK? Triumph 2
KVH TR4/4A Cam Bearings Triumph 6
B TR6 TR6 Differential bearings. Triumph 3
D TR6 Countershaft bearings Triumph 5
Jake OD planet carrier gear bearings? Austin Healey 2
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
