TR2/3/3A Drive end of speedo inner cable to large for pinion
TuffTR250
I recently received a gray 96 inch speedometer cable from TRF to replace the one from Moss that twisted off down by the pinion for the overdrive. I replaced the rubber seal for the bearing and pinion assembly. When I went to install the speedometer cable, the square end of the inner cable that goes into the pinion is slightly too large and won't go all the way into the pinion. I made some measurements of the new cable and some old cables. Here's what I got:
a) New TRF inner cable pinion end is .125" at very end and .127/.128" right where it goes into the cable housing. Won't go into the pinion very far and definitely not far enough.
b) The twisted off pinion end of the 1 year old cable from Moss= .113" at very end and .115" where it goes into the housing. This goes into the pinion very easily it's full length.
c) An old speedo cable that is very used and off a non-overdrive transmission = .120" for the length of the pinion end. This also goes into the pinion all the way and does not have any loose feel, i.e. seems to be exactly the correct size.
A couple of questions:
1) Is it possible to file down the outside of the inner cable without ruining the wrapped metal? It would need to be filed about .007" total or about .0035 on each side.
2) What is the normal size of of the square pinion end of the inner cable? Has TRF's vendor made this end too large?
p.s. the speedo end of the cable seems to go in ok.
Thanks!
Bob
TRopic6
Bob,
I happened to have an NOS 8' Smith's inner cable available (I'm going through boxed stuff in prep for a move). Both ends are .120; I saw no difference at the tip. The gearbox end has about 7/8" of "square" and the speedo end sticks out about 3/8" past the plastic bush. Looks like your repro is a few thou too large, but enough to be a problem.
Those twisted wires are pretty stiff; a careful Dremmel 'adjustment' would probably work.
Jeff
TomMull
busybrit Healey 3000 distributor drive gear spacer washer, end float! Austin Healey 2
I end of long drive symptoms Austin Healey 23
KVH Distributor Drive End Float Triumph 6
mrstinson Stall at Idle [Stop Lights, Signs, End of Drive] Spridgets 9
M TR2/3/3A HVDA Speedometer Drive Triumph 10
RJS TR4/4A Drive Shaft - Prop Shaft Alignment and Balancing Triumph 8
B MGA Tach drive issue MG 1
R Smitty Toyota Conversion Angle Drive Austin Healey 16
3798j Off Topic MGB at the Drive in Bank MG 1
Popeye General Tech O/D right angle drive choices Triumph 10
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
AngliaGT Mixture of Cars on My Drive Today Spotted 8
drooartz MGB First drive of the year! MG 5
OZ_BN1 Drive Shaft Universal Joints Austin Healey 2
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
DocDup1 MGB SpeedBox Speedometer Drive MG 0
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
BritBite Speedometer Right Angle Drive Austin Healey 5
Darrell_Walker TR4/4A Speedo Drive removal (non-OD) Triumph 8
AngliaGT On Today's Drive Spotted 0
jfarris TR2/3/3A First drive of spring - I hate electricity!!! Triumph 7
Zitch Engine Oil Leak After Long Drive Austin Healey 19
D T-Series Shorrock supercharger drive belt MG 7
tr6nitjulius General TR Sir John Black Drive Your TRIUMPH Day 2/10/22 Triumph 0
D Off Topic Remember to drive your Triumph Triumph 3
S TR2/3/3A tack drive on the distributor must have caused those cuts in the gear Triumph 4
R TR6 Drive shaft orientation Triumph 3
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
KVH General Tech Angle Drive Broke (Repost) Triumph 0
KVH General Tech Angle Drive Came Apart Triumph 10
R TR6 1973 Final drive issues Triumph 5
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
F 1954 MG TF for sale, ready to drive and show MG Classifieds 1
C Bugeye propeller/drive shaft- universal joint Spridgets 1
71TR6 TR2/3/3A TR3A Drive shaft cork seal Triumph 10
nichola TR6 Oil pump drive barely engages Triumph 2
T Angle Drive Lubrication Austin Healey 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
L TR2/3/3A Drive shaft question Triumph 5
Lin Tach drive housing for BT7 Austin Healey 4
4tecdog Speedo drive gear Spridgets 15
RJS TR4/4A Speedometer and Angle Drive Triumph 6
J Wanted Front Yoke on Drive shaft Spridgets Classified 2
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
mctriumph Morgan drive line Other British Cars 2
S Speedometer Angle Drive Austin Healey 2
