So I finally had a chance to get under the car to grease up the front end and hopefully solve some of the noise. When I removed the wheels, I discovered the lug bolts had been replaced with non-OE correct ones, literally with the hexagon heads JBWELDED into place, and the nuts had additional concentric spacers to presumably fill the void from incorrect nuts and lugs. Oh yea, and there is a spacer behind the wheel rim? Is this normal, as the car was supposed to have "period restored minilites." What size lug bolts do I need and what size lug nuts should I be using to keep them firmly to the hub. Don't want to drive it much until I get this nightmare sorted.
I also tried to ID the wheels but couldn't find any cast stampings in them at all? Does this sound correct for '60 Minilites?
