TR2/3/3A Carburetor Rebuild
Vacuum retard was only on later cars, not a 57 TR3.
TR2-4 used 4 BTDC (not ATDC) as the factory (static) ignition timing, and then had a very aggressive centrifugal advance so the timing was advanced much more than usual as the engine came off idle. The purpose, I believe, was to make sure the timing was late enough to avoid kickback when hand cranking. With the spark occurring significantly before TDC, all it takes is for the cylinder to be full of combustible mixture and the crankshaft to be moving very slowly, to cause the cylinder to fire and force the crankshaft to turn backwards.
You'd have to check with Jeff for details, but I believe he installs a slower advance curve, such that the total advance is about the same at normal operating rpm, even starting with 16 BTDC static. (Or maybe just a pinch more, the factory total advance is fairly conservative.)
Just for grins, here is a comparison of the centrifugal curves for a couple of TR2-4 distributors, and a TR6 for comparison.
Thank you Randall, with the warning about hand cranking the engine with the aggressive 16 degree BTDC timing.
Interesting. I never thought about hand cranking being the reason for the TR3's odd "knee" on the timing curve, but that makes perfect sense. It essentially acts as a switch, so timing comes in very fast after the engine is started, and then follows a more traditional curve...or rather line.
Last week in this thread I offered Randall a digital copy of the second version of the Triumph Instruction Book (the TR2 book updated with TR3 info), but my PM to him wouldn't allow an attachment. Given that the scanned PDF is over 13mb, I can't post it here either, so I've put on my website as a hyperlink and making it available to all. The link to the page is:
https://losangelesdivision.com/LA_Division/Triumph_Stuff.html
There are two versions, one that is 13+mb, another reduced-size version at 5mb. The latter's scanned pages' photos aren't as crisp, however. Your choice.
Thanks, Keith!
I think there may be some confusion here regarding timing. Triumph called for 4 degrees BTDC static, Jeff at AD calls for anywhere from 10-14 BTDC AT IDLE* with the vacuum disconnected. It's two very distinct ways of setting the timing. I would question how well the case would run if you set 16 degrees static timing.
I agree, how it could. The timing would fall off and run out of advancement before the engine could reach its maximum RPM/road speed and the engine probably bog down.
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
AH67 For Sale CARBURETOR REBUILD KIT, genuine SU, twin HD6 Austin Healey Classifieds 0
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
bigbadbluetr6 TR6 TR-6 Carburetor rebuild kit Triumph 6
PAUL161 SU Carburetor Rebuild Kits MG 16
bluemiata90 TR2/3/3A tr3 carburetor rebuild question Triumph 9
J Carburetor Banjo Seals Austin Healey 11
zoohow TR6 Carburetor Conversion kit Triumph 2
jehuie HS2 carburetor question… now with video! British Motor Corp 20
jehuie Will this lid work with my HS2 carburetor float chamber? British Motor Corp 4
jehuie Wanted HS2 carburetor float chamber cover wanted Spridgets Classified 0
P Zenith Carburetor Triumph 2
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
KVH General Tech HS6 Carburetor Bushings Triumph 10
A Spitfire Weber Carburetor Triumph 0
B gas leak underneath the carburetor Restoration & Tools 2
A TR6 Carburetor help Triumph 5
G TR6 Hacked carburetor? Triumph 6
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
2 For Sale Jet for SU H6 Carburetor Other British Classifieds 0
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY SU Carburetor Synchronizing Kit on eBay Austin Healey 16
C TR6 Carburetor Throttle Linkage Triumph 10
FlyingCat Spitfire No Gas to Carburetor Triumph 18
FlyingCat Spitfire Which carburetor is the best? Triumph 9
F TR6 Carburetor issues at low rpms webers Triumph 23
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
D TR2/3/3A '59 TR3A SU carburetor Triumph 4
AUSMHLY Front carburetor Austin Healey 11
B BJ7 Carburettor / Carburetor spacers Austin Healey 2
G Gasket sequence manifold to carburetor Austin Healey 4
F General MG Help needed with su dual carburetor identification MG 4
KVH TR4/4A Carburetor float bowls Triumph 8
M BN1 carburetor fuel line Austin Healey 9
fpstude TR2/3/3A TR3 Carburetor Adjustment Triumph 6
D S.U. HD8 Carburetor Drawing Austin Healey 6
svtmikey GT6 C.D.S.E.V carburetor question Triumph 5
W Please help ID this unusual [& beautiful] carburetor adapter Other British Cars 4
Lutz Kramer Carburetor gaskets Austin Healey 8
B BT7 carburetor - choke - fuel questions Austin Healey 5
J T-Series Leaking carburetor, old cork seal and new o ring seal MG 1
Keith_M carburetor woes Spridgets 17
C HD6 Carburetor Spacer Blocks Austin Healey 4
C Carburetor Removal on a BT7 Austin Healey 7
C Carbon Deposits in Carburetor Austin Healey 3
T 1933 Standard Little Nine Carburetor Other British Cars 8
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
DornTRoriginal TR2/3/3A Carburetor Link Rod Ass'y Installation and Fuel Line Installation Triumph 1
KVH TR4/4A Carburetor Heat Shield for HS6 SUs Triumph 4
N Spitfire Weber Carburetor Upgrade - 77 Spitfire Triumph 9
