Bugeye front bumper
ichthos
Hello,
I am close to finishing the paint job on my Bugeye. My car was totally taken apart. This is the first car I have ever restored. I have learned a lot along the way, but have made many mistakes also. One current frustration I have is with the front bumper. I was doing a last fitting of parts before I put on the final paint. I can not seem to get the bumper to sit correctly. The bumper was not on the car when I bought it. I foolishly worked on the body and had the front bumper straigtened and rechromed before actually fitting it on my car to start with. I checked the brackets against another pair of bumper brackets and they do not seem to be bent at all. I know I have the brackets on correctly, yet the bumper seems to be pointing up. Any ideas what I am doing wrong or what I can do to correct this would be greatly be appreciated.
Thanks, Kevin
jlaird
Turn it over?? Adjust the brackets??
I
ichthos
Thanks Jack. I have tried every position I can think of on assembling the bumper. I am obviously missing something. I wish I had someone near me with a Bugeye I could compare to. I was worried that the front part of the frame may have been bent up. There was no apparent major damage when I bought the car. The bonnet gaps are fairly uniform. I measured the frame while on jacks and both sides are farily uniform for the surface I had to work with. I am wondering if when the bumper was straigtened that maybe it origninally had a slight angle to it.
Kevin
jlaird
I seem to remember haveing the same problem long ago, solved it by bending the supports till it was right. After all it is not going to protect you from anything.
Billm
As a last resort you could take four thick flat washers and taper them all the same. Put 2 on the stubs behind the bumper and 2 on in front of the bumper (brackets) and align all 4 to angle the bumper properly.
Bill
bugimike
I don't know about not protecting from anything Jack, I hit a brick storefront head-on after skidding on ice in an avoidance maneuver. I had to be doing 15-20 MPH and wiped out the bumper assy. to the point that I could not re-use it, but it sure saved the car! The bonnet got dented & twisted, but that was just bodywork. Frame etc. remained remarkably true & intact! Those brackets acted almost like leaf springs.
leecreek
Swapped the brackets left to right?...Post a pic..
I
ichthos
I am working on the body in a friend's garage. I won't get a chance to get a picture for another couple of weeks. I'll post a picture then. Thanks again for all the suggestions. I am sure you will be reading much more from me soon. Once I finish the body (the tub is totally bare) and put the whole thing back together, I know I will be needing a lot of help.
Kevin
ncbugeye
I just happen to have my front bumper removed right now, so I may be able to help you with pictures. To start off, here is a picture of the bumper with its 4 brackets. Tell me exactly what aspects you want more detail on, and I'll upload more pictures.
ncbugeye
Here is the service parts manual page
T To use front bumper on Bugeye or not? Spridgets 29
mrsprite Bugeye front bumper wanted Spridgets 19
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
W Best source for Bugeye front shocks Spridgets 3
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
Rut Bugeye front tilt latches Spridgets 24
P Bugeye front drum brake picture Spridgets 7
Rut Bugeye front frame rails Spridgets 7
drooartz Front tow eye for a Bugeye Spridgets 11
M Looking for this rare front for a Bugeye Sprite Spridgets 9
P Bugeye Front Wheel Bearings? Spridgets 1
T stock bugeye front springs Spridgets 4
Rut Bugeye front suspension Spridgets 0
B Bugeye front end Spridgets 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bugedd Bugeye front lowering springs Spridgets 0
TulsaFred Bugeye front suspension Spridgets 41
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
I Bugeye wiring help for front turn indicator Spridgets 13
R Bugeye front shocks Spridgets 3
M Bugeye with late model front end ? Spridgets 16
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
I Front suspension rebuild help for bugeye Spridgets 6
I Price for good used front bugeye spindle axle? Spridgets 2
I Bugeye front brake drum temp? Spridgets 2
I 60 Bugeye front suspension torque settings? Spridgets 4
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
T bugeye front tilt bonnet Austin Healey 4
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
N Front line suspension for a Bugeye Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
