Front Steel Insert For Bugeye Top. Anyone Have One
RickB
Too bad you are not looking for the back piece, or are they they same? I have a spare back piece.
Let's search Spritenut's old posts - I am sure he told us several times the right dimensions for this piece and maybe where to get it.
RickB
Just answered my own question at AH Spares.
They list the part#
XHOD145 HOOD RAIL-front MK1-MK2 £7.45
#14 in this image:
mainpicture.aspx
(oh - that didn't work - you will have to go to https://www.ahspares.co.uk and search to find it)
John Kuzman
Per Frank:
A better idea is get a length of 1/8 x 1/2" (or is it 5/8 wide?) flat
mild steel from a hardware or home center store, cut it to size, file or
round over the corners so not to tear the top.
Paint it so it doesn't rust inside the top sleeve.
Frank Clarici
Toms River, NJ
Down to just a few Sprites
bugedd
Or rather than steel, I used aluminum
RickB
My mild steel original gets a bit bendy, how does the aluminum one hold up?
bugedd
Perfect, granted I don't use the hood very often. I like the aluminum, its nice and stiff and holds well
RickB
Apparently Frank answered this one several times - here's another:
"Hood bar dimensions- 9/16" W X 36 1/4" L X 1/16" Thick with rounded ends."
M Front steel brake lines Spridgets 9
maxwedge5281 wtb front drums for steel wheels Austin Healey 1
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
Jim_Gruber One Piece Spridget Front Tilt Steel Bonnet availab Spridgets 12
bighealeysource Installing front fender stainless steel beading Austin Healey 4
A Front - Rear wings/fenders Aluminium or Steel Austin Healey 6
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
