Bugeye front tilt latches
Rut
I've been working on various designs for latches and it's tedious work getting everything lined up, but I think I'm on the home stretch. I wanted to build a latch system that was completely reversible with no modifications to the car and I'm pretty close to that goal. If anyone has done this before I would love some advice on adjustment!
Thanks, Rut
Jim_Gruber
Rut, Did you fabricate the latches and bonnet pins yourself? Talk to us about the "Gotchas" you've encountered?
Bayless
Nice. Looks like a factory installation.
Rut
Rut
Jim,
The latch/pin combos are from an early 70s VW beetle and are pretty inexpensive...they have a built in release if the cable breaks. I tried several styles of mounting and settled on this one since no holes are drilled. I used an old set of 1275 motor mounts split in half, heated and reshaped and a 16 ga plate with a flanged nut spot welded to it. I made templates out of cardboard and then 22 ga sheet to test function and ease of manufacture. Once painted I think it will look pretty decent and blend in.
Rut
Rut
Rut
The toughest part is the alignment of the pin and receiver which is latched in the closed position as I type this. Being off by a fraction of an inch causes the pin to stick and it's a lot if trial and error. The engine bay is small, but it gets very small when I try to get in there to release the pin!
Rut
JPSmit
Ummm I hate to point out the obvious but there is a very small child in your thumbnail photo - just sayin'
Rut
Rut
JP,
Shes a little bit older now and the only way I could get her inside is to tell her there's a princess or mermaid hiding there!
Rut
Rut
Rut
I discovered that part of my alignment issue is in the hinges I'm using. I bought a used set from another forum several years ago and while everything bolts up correctly it doesn't fit MY Bugeye. To solve this problem I ordered a set of hinges from Gerard @ Gerard's Garage yesterday and look forward to installing them. I think it will not only solve my alignment issue, but add a little bling to my car!
Rut
Gerard
hahaha... when my daughter was little she could fit through a gap between two sections of an L-shaped desk and plug and unplug computer cords for me. She's the one that inherited my mechanical aptitude, and it's something she remembers fondly.
Gerard
Nicely done! Looking forward to reports that you've fine tuned and have it working.
Thanks, Rut
SD Bugeye
That's a really nice setup! I have thought about this type latch but have shelved project for now .
nice work ! We're do we send the check for the kit?
Jim_Gruber
I like the idea of if cable breaks latch releases. Now to see what nice hinges do for you. My set from Gerard is downstairs waiting. If you need sooner...
smaceng
The most important aspect on the forward tilting hinges is one that has the pivot point such that the bottom trailing edge of the bonnet does not grind on the bodywork. Not sure how this is too be achieved, but my makeshift ones for my first BE did not quite do the trick. I have always thought the if you could make the hinges fixed to the bodywork, that would be an ideal place to put the latches for the forward tilting bonnet.
Cheers,
Scott in CA
Rut
Rut
One thing I've found is that due to the flexibility of the bonnet the latches are very hard to align. I use the tape method (wide piece of painters tape over the receiver) to show me where the point of the 'pintle' makes contact. With an improper fitting hinge set that position will change each time you close the bonnet and it will jam and it's a pita to break loose. The rear bonnet to cowl seal must be modified as well into a flat piece about a foot long to get the proper fit and curve. I'll also use rubber wedges that the TR4a uses along the side of the bonnet to prevent contact between the cowl and bonnet. Although this project is fiddley it's fun experimenting with the different possibilities and I'll post the ones I have the most success with.
Rut
Rut
Rut
In an on going effort to screw up a good design for a better one I'm going to try using these latches. I can mount the latch pin to the vertical bonnet brace and the latch on a corresponding area of the foot well. I think a low mount will be better to keep the handle away from knees/legs. Thoughts?
Thanks, Rut
nomad
I think those would work slick, Rut!! Similar to an XKE and the way I always thought about doing that. Can I ask what they are off of? They look a lot like Spridget boot lid latch's.
Kurt.
59diamond
This seems like a lot of trouble when all you have to do is stay original and wear a helmet when you are working under the bonnet
Rut
Rut
Too funny!
Rut
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
T bugeye front tilt bonnet Austin Healey 4
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
W Best source for Bugeye front shocks Spridgets 3
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
T To use front bumper on Bugeye or not? Spridgets 29
P Bugeye front drum brake picture Spridgets 7
Rut Bugeye front frame rails Spridgets 7
drooartz Front tow eye for a Bugeye Spridgets 11
M Looking for this rare front for a Bugeye Sprite Spridgets 9
P Bugeye Front Wheel Bearings? Spridgets 1
T stock bugeye front springs Spridgets 4
Rut Bugeye front suspension Spridgets 0
B Bugeye front end Spridgets 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bugedd Bugeye front lowering springs Spridgets 0
TulsaFred Bugeye front suspension Spridgets 41
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
I Bugeye wiring help for front turn indicator Spridgets 13
R Bugeye front shocks Spridgets 3
M Bugeye with late model front end ? Spridgets 16
I Front suspension rebuild help for bugeye Spridgets 6
I Price for good used front bugeye spindle axle? Spridgets 2
I Bugeye front brake drum temp? Spridgets 2
I 60 Bugeye front suspension torque settings? Spridgets 4
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
mrsprite Bugeye front bumper wanted Spridgets 19
I Bugeye front bumper Spridgets 9
N Front line suspension for a Bugeye Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
