bugeye front tilt bonnet
Tman
Hello,
I have been restoring a bugeye on and off for the last 15 years - I wish I would have joined a forum much earlier. In any case, I am very close to finishing this car. I was able to get very nice gaps in the doors, but I am still not happy with the way the bonnet fits. I recently went to a British car show and observed one bugeye with a front tilt bonnet that fit quite nicely. My question is what are the advantages and disadvantages with a front tilt bonnet? By the way, everything is stock at this point.
Thank you
Gray_Cat
Tman:
There are a couple disadvantages when converting the Bugeye bonnett to tilt forward. 1. You can no longer fit the front bumper as the bonnet will hit the bumper if tilted forward. Also means you need to fabricate something to display your front license plate as well. 2. Authenticity. Depends on how much of a purist you want to be. You would loose points for the conversion at a concours but I don't know if you will be entering shows or not.
There is a huge upside - unfettered access to the engine compartment. Working under the original style set up (raising the bonnet from the front) is a literal pain in the back. You can get conversion kits from various vendors, or do it yourself. Having a restraining cable is a good idea to keep from stressing the mounting points too much when tilting the bonnet forward.
When my Bugeye is finished, the bonnet will tilt forward.
Regards
Roy
Roy
Keoke
HI Tman, the only advantage I know of is slightly better access under the bonnet when the bonnet is hinged at the front.---Fwiw---Keoke
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
Rut Bugeye front tilt latches Spridgets 24
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
W Best source for Bugeye front shocks Spridgets 3
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
T To use front bumper on Bugeye or not? Spridgets 29
P Bugeye front drum brake picture Spridgets 7
Rut Bugeye front frame rails Spridgets 7
drooartz Front tow eye for a Bugeye Spridgets 11
M Looking for this rare front for a Bugeye Sprite Spridgets 9
P Bugeye Front Wheel Bearings? Spridgets 1
T stock bugeye front springs Spridgets 4
Rut Bugeye front suspension Spridgets 0
B Bugeye front end Spridgets 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bugedd Bugeye front lowering springs Spridgets 0
TulsaFred Bugeye front suspension Spridgets 41
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
I Bugeye wiring help for front turn indicator Spridgets 13
R Bugeye front shocks Spridgets 3
M Bugeye with late model front end ? Spridgets 16
I Front suspension rebuild help for bugeye Spridgets 6
I Price for good used front bugeye spindle axle? Spridgets 2
I Bugeye front brake drum temp? Spridgets 2
I 60 Bugeye front suspension torque settings? Spridgets 4
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
mrsprite Bugeye front bumper wanted Spridgets 19
I Bugeye front bumper Spridgets 9
N Front line suspension for a Bugeye Austin Healey 4
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
