60 Bugeye front suspension torque settings?
ichthos
Still at it putting my car back together. Does anyone have torque settings for the front suspension? At the moment I especially need torque settings for the four spring seat bolts and the three shock (damper) bolts.
Thanks,
Kevin
JPSmit
don't know that there is a torque setting - however, most times when you are bolting things to steel plate from memory I think they want about 40 lb
jlaird
Torque setting are baised upon the diameter of the bolt in question. In fact there is a chart on the web someplace that gives all.
However, for those just snug up tight makeing sure the lock washer is flat and all will be good.
jlaird
Easy isn't it when you break the code.
Rut Bugeye front suspension Spridgets 0
TulsaFred Bugeye front suspension Spridgets 41
I Front suspension rebuild help for bugeye Spridgets 6
N Front line suspension for a Bugeye Austin Healey 4
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
W Best source for Bugeye front shocks Spridgets 3
R Wanted Bugeye front side lights (clear lens) Spridgets Classified 3
Kurtis Bugeye Sprite front frame rail horn replacement Spridgets 5
Keith_M bugeye front tilt hood fastener -- choices Spridgets 9
T For Sale For Sale: Bugeye Front End Spridgets Classified 0
T To use front bumper on Bugeye or not? Spridgets 29
Rut Bugeye front tilt latches Spridgets 24
P Bugeye front drum brake picture Spridgets 7
Rut Bugeye front frame rails Spridgets 7
drooartz Front tow eye for a Bugeye Spridgets 11
M Looking for this rare front for a Bugeye Sprite Spridgets 9
P Bugeye Front Wheel Bearings? Spridgets 1
T stock bugeye front springs Spridgets 4
B Bugeye front end Spridgets 0
C Bugeye Disc Front Brakes FORUM Navigation Questions 0
C Bugeye Disc Front Brakes Spridgets 4
bugedd Bugeye front lowering springs Spridgets 0
regularman Has anyone here put a bugeye front end on a square Spridgets 2
T My buddy Rocco in my 64 Sprite [with bugeye front] Spridgets 2
6 Front Steel Insert For Bugeye Top. Anyone Have One Spridgets 7
I Bugeye wiring help for front turn indicator Spridgets 13
R Bugeye front shocks Spridgets 3
M Bugeye with late model front end ? Spridgets 16
toysrrus Bugeye: "FRONT TILT OR REAR TILT"? Spridgets 16
I Price for good used front bugeye spindle axle? Spridgets 2
I Bugeye front brake drum temp? Spridgets 2
Jim_Gruber Front Hinged Bugeye Bonnet/Getting to curve back i Spridgets 6
mrsprite Bugeye front bumper wanted Spridgets 19
I Bugeye front bumper Spridgets 9
T bugeye front tilt bonnet Austin Healey 4
Steve P. Bugeye front bonnet tilt: anyone built their own? Spridgets 3
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
