Front tow eye for a Bugeye
drooartz
Any reason the tow eye (Moss 400-575) from the later cars wouldn't work on a Bugeye? I'd really like to have a better tie-down point for the front for when the shell gets towed home after paint is done.
drooartz
drooartz
Thanks, Bill. That's what I thought, just wanted to be sure.
Jim_Gruber
Is that a bolt on or welded item?
drooartz
drooartz
Bolts on to where the bumper brackets bolt to the body. Present, I believe, on all square Spridgets. Often quite mangled on older cars from contact with the ground, parking curbs, etc.
Jim_Gruber
Ok it's a bolt on to Bumper bracket frame horns.any reason this can 't be used with a Front Tilt kit if it goes to the inside of frame rails. Probably would need to be welded on as only room for one bolt to attach it with forward tilt kit. But could bolt on one side and weld all around. Hmmm idea on process.
jlaird
As crazy as life is I added these tie downs to Miss Agatha today. Finally found the ones I had stashed away.
OK, now I can get to the front easily to tie things down, what about the rear. Must be a simple way for an old guy.
nomad
Well, Jack, your wheels are too nice but hooking in a hole in the rim work's!:encouragement:
Kurt.
64rocksprite
Guys - just sharing experience from my pain..if towing over a long distance..best to use a strap that holds the wheels to the trailer. lets the body/suspension move without affecting the tie down straps.
Now granted, I was on a 1600 mile trip, but I had a strap over the two front rails to the floor which failed during day 2..allowing my car to roll forward and backward in the (luckily enclosed) trailer when I stopped/started, buggering the trunk handle, denting the 'boot lid', and some rear light damage.
My next trip, I ante'd up for some over-the-wheel straps..she doesn't move an inch now..
$20 at US cargo control..
drooartz
drooartz
I used over-the-wheel straps when I brought Penny home last year -- worked well, though that was on a purpose-built trailer. Now my need is just for the flatbed tow truck ride 50 miles home from the body shop.
Rut
Jack has a lightweight trailer for Miss Agatha and we talked about an easier way to strap it down. It's a little tough for me to get on my hands and knees and put straps over the axles. We commented on this at Brits on the Bay and I came up with this.
Rut
jlaird
And these will work great as soon as I get to bend them more like a 45 degree angle. Thank you Rud, you a good friend.
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
craigshealey3000 Front End Shake Austin Healey 31
K TR2/3/3A Centering the brake rotors(disk)s in the front brake calipers using the shims? Triumph 5
