Front suspension rebuild help for bugeye
ichthos
Does this seem like a reasonable sequence to put my front suspension back together?
1)Install lower A arm and put in lower fulcrum pins and bushings. (Do bushings get greased?)
2)Put in spring (Use a conventional spring compressor? Do I leave springs compressed throughout procedure?)
3 Attach upper portion of spindle axle to the shock with upper fulcrum and bushings.
4)Install lower fulcrum with cork washers (I am confused by what cork washers to use. I think I have corks from two kits. I have four cork washers with an ID of 13/16", four with an ID of 3/4", and four washer with a beveled inside edge with an ID of 11/16".)
I was told I needed to have the brake lines in first before I do this. I don't have the money for the brake lines at the moment and would like to move forward. Since there is nothing else in my car engine bay at the moment it looks to me like I can do this later. I have never done this before, so any suggestions would greatly be apprecitated.
Thanks, Kevin
JPSmit
looks good - bushings don't get greased.
general wisdom is kick in the springs. Lower the A-arm as far as it will go, put the spring in - top first - kick in the bottom then use your jack to compress the spring (under the A-arm) to where you can bolt up the top
Jim_Gruber
I'd go for the helper bolt trick. Kicking springs out is one thing, 2 longer bolts to help compress the spring until you can get the regular bolts to threat. I use threaded rod. Helps if you've got a really deep socket.
You will have a fairly hard time compressing the springs with a jack from underneath, if you have no engine in the car...
mark
Jim_Gruber
Also, don't put the trunnion on backwards. If you do, wheels will really stick out funny. You'll know you did it wrong when you lower the jack and stand it on it's own wheels.
Brake lines, if you are talking flex hoses, they can be done and changed later. If new hard lines, spend a few extra bucks and get the prebent lines. Will save you a whole lot of time and effort.
Pythias
Someone (just brits .com ?) supplies A arm Fulcrum pins with threaded to accept a zerc fitting at both ends. worth it to track them down if you don't already have a set.
Whitephrog
I put the springs in last with the help of a series of bolts of various lengths.
drooartz MGB Front suspension rebuild is next MG 57
J Front Suspension Rebuild Austin Healey 16
M front suspension rebuild parts list Spridgets 22
M TR2/3/3A TR-3B front suspension rebuild Triumph 0
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
bugedd About to rebuild my front suspension Spridgets 1
boxfullofyertoys Front suspension rebuild issues Spridgets 11
R Front Suspension rebuild MG 12
Stinger TR4/4A TR4A Front Suspension Rebuild Triumph 26
jbowlby MGA MGA Front suspension rebuild MG 1
T Front suspension rebuild - TRF kit or piece parts? Triumph 5
T Correct/best order for front suspension rebuild Spridgets 8
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
I TR6 TR6 front suspension rebuild suggestions Triumph 19
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
Jayrz Front Suspension rebuild sequence MG 41
M Front Suspension Rebuild Triumph 21
1 front suspension rebuild, parts? Austin Healey 2
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
John_Mc Front suspension rebuild revisited Triumph 21
John_Mc Front suspension rebuild Triumph 23
John_Mc TR6 Front Suspension Rebuild TR6 Triumph 16
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
jcatnite Front suspension rebuild Spridgets 8
Bill Redd Front Suspension rebuild Triumph 8
77MidgetMkIV front suspension rebuild [spring refit specificall MG 9
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
