Front suspension rebuild - TRF kit or piece parts?
tdskip
Looking for opinions here as the merits of the TRF "all-in-one" rebuild kits vs ordering the parts separately. I used the all in one TRF on the TR6 and it was mighty nice to have everything arrive in one package, albeit for a first timer it took a bit to sort out the jumble of parts.
It did make me wonder if the inner steel sleeves and bolts etc were overkill and if I could save some money by trying to re-use them and just ordering the replacement bushings etc. BPNorthwest provides some very nice poly bushings....
Is it considered good practice to replace all the sleeves and bolts as a matter of course? What do you think?
(last question for the day - probably...) :laugh:
trfourtune
It depends on the performance level you are trying to achieve. I do not know the quality of the hardware in that kit (nut, bolts,etc) and i am very picky about this stuff. Most kits (i don't know about this one) do not have high quality hardware. I want grade 8 or better hardware for everything and hardened washers. Kits tend to save you money if you use them as is. If existing hardware is questionable at all, replace it. 50 year old rusty nuts and bolts all get replaced as far as I'm concerned, but not with cheap junk.
IMHO
Rob
TR4nut
I'd piece it. The all-in-one kits are great if you are in a hurry, but there is no discount there by buying in bulk in my opinion. I think you can save significant money just by picking and choosing what you want even if you buy entirely from TRF.
TR3driver
Great Pumpkin - R.I.P
I haven't run the kit price vs individual prices; but there do seem to be many items in the kit that I wouldn't necessarily replace. I tend to always reuse the original bolts unless there is some reason not to (thread damage, excessive rust, rounded head, etc) and nuts (ditto) unless they are Nylocs. Nylocs should be replaced every time, as should all lock washers (though I'll admit I usually reuse the special lock washers on the caliper bolts).
My shock brackets (RFK737) are still original, although it wouldn't hurt to replace the lock tabs (or use Loctite). Upper ball joints seem to last a long, long time for me so I generally reuse them at least twice. They are also easy to change later if need be.
Silentblocs (RFK1315) were a high-failure item for me, so I replaced mine with brass/SS ones (from BFE) many years ago. Today I'd recommend the Delrin ones (made by ARE, but available from TRF as P/N HP301)
Likewise, the rubber upper inner bushings only seemed to last a few years, so I replaced mine with Nylatron. Urethane would probably work as well.
I'm still using original side plates (included in RFK1332), but I'll probably replace them next time. I've no idea why, but it seems like they wear quicker with the Nylatron bushings than with the original nylon. Maybe the Nylatron just lets the suspension move easier, so it moves more.
The thrust washers and outer washers (RFK1333) are generally reusable; after all, there is an adjustment for wear.
Oddly enough, the kit doesn't seem to include the 3 bolts that hold the spring pans to the A-arms. They are generally reusable, but sometimes get damaged from rocks & whatnot being thrown up. (Chase the threads, use new cotter pins)
If your stub axles are damaged at all, this might be the time to replace/upgrade them.
M_Pied_Lourd
Skip,
I tend to do an assesment of what I can re-use vs what I can't and then make the decision. I think that you will find that if you buy the kit you will end up having some extra parts (and associated expense) that you will not require.
Cheers,
M. Pied Lourd
drooartz MGB Front suspension rebuild is next MG 57
J Front Suspension Rebuild Austin Healey 16
M front suspension rebuild parts list Spridgets 22
M TR2/3/3A TR-3B front suspension rebuild Triumph 0
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
bugedd About to rebuild my front suspension Spridgets 1
boxfullofyertoys Front suspension rebuild issues Spridgets 11
R Front Suspension rebuild MG 12
Stinger TR4/4A TR4A Front Suspension Rebuild Triumph 26
jbowlby MGA MGA Front suspension rebuild MG 1
T Correct/best order for front suspension rebuild Spridgets 8
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
I Front suspension rebuild help for bugeye Spridgets 6
I TR6 TR6 front suspension rebuild suggestions Triumph 19
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
Jayrz Front Suspension rebuild sequence MG 41
M Front Suspension Rebuild Triumph 21
1 front suspension rebuild, parts? Austin Healey 2
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
John_Mc Front suspension rebuild revisited Triumph 21
John_Mc Front suspension rebuild Triumph 23
John_Mc TR6 Front Suspension Rebuild TR6 Triumph 16
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
jcatnite Front suspension rebuild Spridgets 8
Bill Redd Front Suspension rebuild Triumph 8
77MidgetMkIV front suspension rebuild [spring refit specificall MG 9
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
