Front Hinged Bugeye Bonnet/Getting to curve back i
Jim_Gruber
Looking for some help and advice in getting final fitment on a front hinged Bugeye Bonnet on my '68. I can get things close with the front hinge bracket but I'm still about a 1/2" too far forward. The tolerances and clearances are extremely tight and I did need to do a little trimming on the inside of the Bonnet to get the Oil Cooler to fit.
I've also got an issue with back side of bonnet where it fits across the cowl is absolutely flat instead of curved. I need ot put some curve back into the top of the bonnet. I'm thinking of disconnecting the front hinge setup and rebolting to rear hinges to see if gravity and correct positioning on the rubber seal can get some curve back in the bonnet. That and once it is in proper alignment I can mess some more with the front hinge and see if I can get it to line up.
Anyone got some good tips or tricks on forward tilt bonnet alignment.
Anyone got some tips or tricks on putting the curve back in the bonnet.
fabmandan
Could you epoxy in a piece of metal matched to the curve of the cowl?
Jim_Gruber
Jim_Gruber
No that might work if there was too much curve but bonnet top is flat, i.e. bonnet must have been laying down and someone put something on top of it thus removing the curve. It appears to not be kinked but....
JPSmit
seems to me Jack had a similar issue and got good results with a 2X4 on the engine and careful pushing
Jim_Gruber
Jim_Gruber
Yes I've thought of that. This is a two person job. I'm thinking if I put the bonnet back on the Spridget Hinges, I might be able to get it to come down, fit against the cowl, and try to get the curve back in. That might also allow me to see what else is holding it from the front hinge side, from going back another 1/2 ". Gaps on fender sides, wheel wells do not line up. I have removed the side stays in there to make it more flexible at least for now. If worse comes to worst I may need to work up a template, body buck, of cowl and use the BFH. Another thought is to drill out the brace under there, put it on the body buck and reweld into place.
That's the worst scenario that I do not want to do. Well worst scenario is decision that this one will not fit and go back to Spridget hood and fenders. But it looks so cool hinged forward and access to engine is absolutely so easy. Not there yet however.
jlaird
2x4 in a towel on the battery lower the bonnet and push as needed. Now someone tell me how to get a bit of curve out?
Jim_Gruber
Jim_Gruber
Jack, spent time with front hinges last night and it appears since I did not have all he way bolted down, just lower bolt in place that hopefully I did not have enough spacers in there and reason I could not get all the way back was hinge bracket hitting against the bumper iron and not rotating all of the way back. That and I need to reroute oil cooler hoses. They were hitting against bottom of bonnet as I ran them around the radiator. Ran out of time last night and didn't have a helper. Even with bonnet suspended from ceiling via a pulley manhandling by yourself is not recommended.
One tip, before you try to do this yourself, disconnect and cover the positive battery terminal with tape. Too easy to accidentally short things out manhandling a Bugeye bonnet by yourself. No I didn't have that happen but I saw where it could easily happen.
I'll try the 2 x 4 trick once I'm sure the bonnet is aligned properly. Looking closely last night, inside brace looks good, top of bonnet needs to be simply "sprung" bak into shape. Thanks all.
Jim_Gruber Front Hinged BE Bonnet rubbing on radiator - Spridgets 7
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
P MGB 1974 MGB front spring length. MG 0
B TR4/4A Spax, Gaz and Koni on Front Triumph 12
G TR2/3/3A TR3A Front Sway Bars - Choice? Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
G MGB '71 MGB Front End Rebuild MG 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
X Front End Alignment Austin Healey 14
FrogPond "57 100E Front Hubs on E494A Spindles ? Other British Cars 6
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
craigshealey3000 Front End Shake Austin Healey 31
