BJ7 vs. BJ8
joeq
Bruce Bowker
If you are serious about buying a Healey you should consider getting one or more of some of the better books. Or maybe a good library has them. I have found that reading these books from cover to cover a few times really gives you an insight of the cars, what to expect, what to look for and what the differences in models and years are. Well worth the investment before buying any older car.
Bruce Bowker
Saw in your one post that you have to figure out where to keep your car. My first new "old" car, the white E type came from Manhatten. Always garaged but boy I don't envy paying those rates or driving in the city. Hope you find a good safe place.
J
joeq
it's absolutely nuts – a guy i know from the neighborhood owns a garage and he just raised his prices (again!) to $600 a month... $800 for oversized cars! and that's before the 18.25% parking tax!
J
joeq
the book i'm reading (haynes great cars: austin healey) mentions that, with the bj8's, the "ground clearance problem was finally addressed"... but it doesn't say how much of an issue it was previously. if i get the bj7, am i going to be constantly scraping metal on rough roads? is there a workaround?
thanks.
Bob Claffie
The change from BJ7 to BJ8 included some suspension changes ala the rubber bumper MG. The ride height was raised (I believe at the USofA's request) to get the headlights up higher. More "big brother" involved in the automotive field. Older Healeys ground clearance not a problem, provided you don't drive stupidly. Now you know why their tailpipes slant up rather than come straight out,(clearance).Bob
catfood
You also need to make sure your springs are in good nick. I hand the front and rear of mine rebuilt a few years ago and ended up with another inch of ground clearance even after it had all settled. Urban legend says that you suspensions OK if you can stand a (UK size) cigarette packet on its end under the lowest part of the suspension! As I don't smoke I've never tested that one!
John Loftus
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by joeq:
aside from the wood dash, the differences aren't enormous. is this page missing anything particularly significant?<hr></blockquote>
The interiors are quite different with the BJ7 seats, dash, instruments, tunnel area being of the older Healey style. The BJ8 has a wood dash, new instrument control layout, Ambla trim and center console. This new interior treatment is considered to be more refined, a sort of Jaguar style. Some prefer the old look, some prefer the new. The BJ8 motor has a hotter cam and larger carbs giving it more horsepower .. 148(BJ8) vs. 131(BJ7).
The frame was changed on the BJ8 to allow more travel at the rear. The BJ7 has 4" of deflection rated for the springs while the BJ8 has 5.5". The downside of the increased rear travel is a larger gap between the rear tire and wheel opening that is not as nice visually.
Another change is the BJ7 had a power brake booster as an option .. on the BJ8 this is standard.
Those are the major differences ... best to look at them in person to see what you gravitate too.
Cheers,
John
BJ8Healeys BJ7/BJ8 Exhaust Systems Austin Healey 24
W For Sale Hardtop for BJ7/BJ8 on BaT : No Reserve Austin Healey Classifieds 2
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
P Moss Motors front brake calipers [BJ7 to early BJ8] Austin Healey 8
J BJ7 Mark II with BJ8 Dash Austin Healey 11
B New Window Seal for BJ7/BJ8 Roll Up Windows Austin Healey 1
B BJ7 & BJ8 Interior Rear Quarter Panels Austin Healey 12
healeydan BJ7/BJ8 Vent Window Corner Block Austin Healey 13
D BJ8 muffler on a BJ7? Austin Healey 6
J Can A BJ7 Two Light Schroud Be Coverted To A Four Light BJ8 Style? Austin Healey 6
60TR3A BJ7/BJ8 Boot Cover Question Austin Healey 15
Brinkerhoff BJ8 & BJ7 barn finds Austin Healey 1
D Installing BJ7 version exhaust system on my BJ8 Austin Healey 3
AUSMHLY Window Regulator BJ7 vs BJ8 Austin Healey 26
AUSMHLY BJ7/BJ8 Convertible Top Austin Healey 34
F How much of a premium? BJ8 vs. BJ7? Austin Healey 16
B BJ7 / BJ8 drainage channel Austin Healey 13
B Mechanical & body service parts manual BJ7/BJ8 Austin Healey 2
B BJ7 & BJ8 soft top rear seal Austin Healey 2
B BJ7 or BJ8 soft top replacement Austin Healey 7
HealeyPassion BJ7 or BJ8 Nical hardtop ques. Austin Healey 1
Schroeders BJ7 Exhaust on a BJ8: do I need downpipes? Austin Healey 10
chicken Are BJ7 doors the same as BJ8 Austin Healey 8
GregW Measurement for shut pillar top piece BJ7 or BJ8 Austin Healey 6
L BJ8 Cam with BJ7 Engine? Austin Healey 1
David_K Dynaplastics Hardtop Value [BJ7/BJ8] w/Pictures Austin Healey 11
John Loftus BJ7-BJ8 windshield seal cut Austin Healey 6
J Doors different between a Bj8 and Bj7? Austin Healey 5
5 WTB: BJ7 Squab Austin Healey 13
5 BJ7 Boot Rust-Through Austin Healey 13
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
Walter74 BJ7 Throttle Linkage "Support Panel" Austin Healey 5
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
R New Hood for BJ7 Austin Healey 3
chicken BJ7 Chrome Trim Austin Healey 15
JMACENGINESHOP BJ7 Engine Rebuilding Austin Healey 23
R BJ7 Rear Axle Maintenance Austin Healey 5
B Wanted Grill Top Cowl and Surround - BJ7 Austin Healey Classifieds 1
R Changing BJ7 Differential Ratio Austin Healey 10
X Trouble shooting trafficator - 1963 BJ7 Jaguar 9
T BJ7 Hard to find First Gear when G/Box is hot Austin Healey 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
chicken BJ7 Door Fit Austin Healey 27
T Wanted BJ7 parts needed Austin Healey Classifieds 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
D BJ7 Clutch Austin Healey 6
R BJ7 Back Seat-Rest Austin Healey 1
