TR2/3/3A Advice on TR3 rear bumper overrider source
Bruce100
I need to buy a pair of these. Anyone recommend a source? I have looked at the Roadster Factory, and from a guy on EBay called JORGE CERVERA who seems to manufacture his own. I want good quality on sale. Suggestions?
I got about ten....all in the same condition....needing to be rechromed, But at least they are original pieces of equipment. When I get to that point of needing them.... off to the chrome shop they go!
I got a pair from TRF about six years ago, and they still look good....
My originals are dented. Was thinking rechroming might be expensive? Anyway, I did end up ordering a pair, looks like either option/vendor is good. Thanks all.
I got a pair of rear over-riders from Jorge several years ago. Quality is fine and fit was good.
Bruce100 said:
My originals are dented. Was thinking rechroming might be expensive?...
Not sure how it is elsewhere, but at the shop I use they do not charge any extra for repairing dents, bends or even pretzel-shaped bumpers.
Just as a guide, Denver Bumper charges $60 each for the front overriders and $65 for the rear bumperettes, $200 for the bumper bar - $450 total. That includes dent removal, rust removal, straightening, etc. Cheaper than buying new ones! I see that you are in Arizona, so pricing shouldn't be much different than here in Colorado. Mine are ready to pick up tomorrow! Can't wait to see how they look!
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
T TR2/3/3A Seeking advice on how to repair TR3 steering wheel broken spoke. Triumph 8
Got_All_4 TR2/3/3A Looking for advice in driving a TR3 with overdrive Triumph 6
N TR2/3/3A Looking for expert appraisal advice re possible TR3-B purchase Triumph 3
H TR2/3/3A Cant get my Tr3 engine to start. any advice? Triumph 29
R TR2/3/3A TR3 Seats - Need advice Triumph 9
J TR2/3/3A Brake line advice for my TR3 Triumph 5
H TR2/3/3A TR3 Clutch Advice Triumph 11
H TR2/3/3A TR3 Front End Rebuild -- Tips, Advice? Triumph 17
GBRandy TR2/3/3A I may have found a TR3....but I want your advice Triumph 58
K TR2/3/3A Advice on relocating TR3 chassis fulcrum pin.... Triumph 1
B TR2/3/3A TR3 front bearing/hub advice needed Triumph 6
B TR2/3/3A Advice needed - cleaning TR3 brake pipe union Triumph 11
B TR2/3/3A TR3 piston/liner advice Triumph 5
K TR2/3/3A TR3 upgraded cams & richer SU needles?Advice? Triumph 5
mrv8q TR2/3/3A TR3 Water pump/Engine mount advice Triumph 2
JM1NA TR2/3/3A Possible TR3 purchase, some advice, please.... Triumph 13
tr6web TR6 Need advice removing downpipe nuts Triumph 4
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
J MGB Advice for new MGB owner? MG 16
R Weber DGV Advice Requested… TVR 19
Joel Lester TR2/3/3A Advice on how to get VIN number stamped into new plate Triumph 10
W Need advice on installing new side curtain glass Spridgets 1
edkap2002 TR6 starter motor advice Triumph 12
MadRiver TR5/TR250 Water pump housing removal advice Triumph 0
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
F TR2/3/3A Leaf spring advice Triumph 16
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
HealeyRick BJ8 Repaint Advice Sought Austin Healey 15
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
S TR2/3/3A Troubleshooting Advice Triumph 25
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
N Need brake bleeding advice Spridgets 6
S Heater and fan control replacement - any advice? Austin Healey 9
K TR2/3/3A TR3B Tire/Wheel Advice Triumph 2
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
AngliaGT Thoughts/advice on Miatas? Other Cars 22
B Austin America advice Other British Cars 2
N Electrical Troubleshooting Advice Needed Spridgets 6
L 100/6 tuning and suspension ugrades advice Austin Healey 7
Jim_Gruber Help and Advice needed for post pressure washing debacle Spridgets 10
Jer Thinning the collection, need some advice on pricing parts including a hardtop Spridgets 8
R TR2/3/3A Stromberg vs. SU carbs [discussion/advice] Triumph 17
steveg Advice wanted on HF impact wrench purchase Austin Healey 12
Bayless Need wheel bearing advice please Spridgets 4
W Advice please on 1930's? steering wheel and rack Other British Cars 3
