Hi all,
I picked up a J Type OD (PO says worked fine), mounting plate, and shorter driveshaft recently to install in my Spitfire - note that it has a 1500 engine in it now. J type Any recommendations? Current plan is to install new U Joints, change oil in Transmission. Since I don't know what oil was used in the OD, I was thinking of changing the oil, cleaning the Sump Filter and Pressure Filter per Haynes. Also going to inspect clutch and replace as needed.
Never had an OD before so any advice appreciated.
