A type overdrive that has been sitting for years
Got_All_4
I bought the 69 TR6 last year and I'm planning to do the tear down this winter. But before I do I would like to test the overdrive. This car has been sitting since 1982 in a controlled environment and wondering what should be done to test it? Should i simply put the rear end up and run the engine and put everything in gear and watch and listen what happens? By the way it is not driveable.
That'll work. When I was putting mine together and wanted to see how/if the OD was working, (the car hadn't come off the jack stands yet) I started it up, put it in top gear and operated the OD switch. The speedometer changed speed, up and down, as the OD went in and out.
You really want to at least look at -- and probably change -- the motor and tranny oil before you run this Rip Van Winkle car.
Raise both ends of the car. Try to support it with jackstands or such so that is is level. Then after checking fluids and turning your fuses in the fuse box, test in place.
Reason why I say level and not rear end elevated; is the overdrive shares fluid with the trans. If you have the rear end elevated and the fluid slightly low it may starve the pickup for the overdrive pump...
If you put the car in gear(2nd,3rd, or 4th), turn on the ignition and flip the switch, it will at least tell you if your solenoid is working. If not,check your connections. If you can hear it click, put it in the air as described. If it does not kick in when testing, you may have to pull the transmission tunnel and try to activate it manually by pushing the lever on the passenger side by hand.
Good Luck!
Ok very good info. The transmission cover is off. If the overdrive unit shares fluid with the trany is it regular gear lube? Would it be a good idea to change it before testing?
It wouldn't be a bad idea to change it. I use non detergent 50 weight, others prefer non detergent 30 weight.
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R A Type Overdrive reassembly question Austin Healey 3
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
