A Type Overdrive reassembly question
RonR
I have recently reassembled the two halves of the overdrive. I used a spare transmission main shaft to align the splines in the sun gear with the spines with the unidirectional clutch. The force needed to rotate the sun gear seemed excessive. I am wondering if the sun gear end float is insufficient, even though I reassembled the overdrive using the same thrust washer and adjusting washer that were in the overdrive when I disassembled the unit. These two washers set in front of the sun gear.
Any thoughts?
Thanks.
Ron
I think the drag on the parts was higher because the parts were dry and had no lube on them??---Just a thought
I did grease the washers before assembly. I probably shoud take it back apart and measure the end float.
Good Idea--N Leave grease out--:encouragement:
71TR6 TR6 Type-J Overdrive identification Triumph 4
T TR2/3/3A A type overdrive hard engagement Triumph 36
R TR6 J-Type overdrive will not disengage when warm Triumph 8
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
Graham H TR2/3/3A A type overdrive Triumph 6
KVH General TR Type A Laycock Overdrive Questions Triumph 8
C TR2/3/3A A-type overdrive drain plug oring Triumph 1
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
CJD TR2/3/3A A type Overdrive Seal Triumph 9
T Spitfire J Type overdrive Triumph 2
T TR2/3/3A Question on A-type overdrive solenoid Triumph 21
BillyB62 TR2/3/3A Type A TR3 Overdrive Wiring Triumph 13
T TR2/3/3A Question on A type overdrive spec for "clutch movement from direct to overdrive" Triumph 7
M_Pied_Lourd TR6 J Type Overdrive High Pressure Filter Cap-Major Problem Triumph 6
R TR2/3/3A A-Type overdrive question Triumph 8
T TR2/3/3A My A-Type overdrive rebuild project, some questions Triumph 36
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R Overdrive [Type A] brake ring gaskets Austin Healey 1
R TR2/3/3A Overdrive [Type A] Brake Ring Gaskets Triumph 14
J General TR D Type overdrive not working need suggestions Triumph 5
Gordon_Dedrick TR2/3/3A A type overdrive installation Triumph 7
T TR2/3/3A Type A Overdrive, Physical Differences between Roadster Brands? Triumph 2
T TR2/3/3A Type-A Overdrive Handling Differences Triumph 9
A TR5/TR250 A-type overdrive questions Triumph 25
71tr TR6 Overdrive Mount / J-type on A-type frame Triumph 1
D TR6 76 TR6 J Type Overdrive Triumph 7
Gordon_Dedrick Testing an A type overdrive Triumph 20
Simmo I need help with J Type Overdrive Triumph 15
Q "A" Type Overdrive Annulus End Float!! Triumph 4
D A type overdrive question. Triumph 3
John_Mc J-Type overdrive for sale on CL Triumph 4
KVH More on A Type The Overdrive Triumph 2
Coyote1 J Type Overdrive engage problem Triumph 3
J A Type Overdrive Triumph 17
K TR6 TR6 J Type Overdrive...Link to Schematic? Triumph 3
O J Type Overdrive Conversion Triumph 19
Marvin Gruber J type overdrive unit on BCF classifieds Triumph 2
HerronScott TR4/4A TR4A A-type overdrive and Moss Europe TR2-4A cat. Triumph 2
T A-type Overdrive & Gearbox Triumph 9
TR3TR6 J-type overdrive question Triumph 5
CinneaghTR A-type Overdrive Model Number Triumph 14
71tr J-type Overdrive Pressure Port Question Triumph 2
T A-type overdrive / gearbox trouble shooting Triumph 69
R_Lyle TR6 J-Type or A-Type Overdrive for 1972 TR6 Triumph 18
TR4A_IRS Looking for a J Type Overdrive? Triumph 0
