'70 Series II engine bay wiring harness --
Goodfellow
I have purchased a new engine bay wiring harness for my restored Series II. According to the SNG Barratt catalog, it is the correct part number for a Left hand Drive Series II (part #JL-202).
Unfortunately when I looked at the bonnet bulkhead connector from the old harness, I noticed that it had seven wire connections versus the new harness which only has six. All my wiring diagrams from the factory manual and from every Jag site that I could find shows only six connections.
This is the connector in question -- shown is the original connector with seven wires. The extra wire in question is the larger gauge wire on the far left hand side that is connected to the #6 bonnet bulkhead plug connector pin.
This is the wire that isn't found on the newly purchased harness.....
...... and is connected to the #6 plug pin.
The original wiring diagram shows only six connections -- and no mention of this #6 wire. It looks like the wire color was originally white with a very thick red tracer swirling around it. --- or it could also have been a Red wire with a White tracer -- not sure at this point
Has anyone run across this problem with their cars? I should mention that this car has power brakes and AC.
Any help would be appreciated.
My apologies for the double post -- I don't know how it happened, but simply to ask the mods to remove one of these.
Thank you!
I wonder if a DPO had done the headlight relay trick and that big fat red wire is the dedicated power feed.
The red with a yellow tracer is for spot lamps. Not sure what the above massage is about?
Thank you!! -- so there actually was a special wiring harness that included a separate heavy gauge wire for the rally type spot lights in the front of the car? I have only seen those spot lights on European E-Types. Never knew they were part of the factory wiring harness or that they were imported with that option into the US.
Your welcome. All english vehicles are wired with the same colour code of the wires. You will likely find that the wire terminates near the facia.
Thank you Geo Hahn -- that is exactly what I was looking for. Many thanks for all the helpful comments in this entire thread. --- Much appreciated!
G '70 Series II engine bay wiring harness -- Jaguar 3
sim A-series Engine Block Search Spridgets 2
A Making an A-series engine stand adaptor fitting Spridgets 2
M Photos Needed of Series III E-Type Engine Oil Filter Clearance at Exhaust Manifold Jaguar 1
dklawson MGB Nissan Engine/Head Equivalent ??? Datsun B-Series? MG 3
Boink Cut-away B series engine... MG 6
theleisure Inside an A-Series Engine Spridgets 6
78Z B-series Engine ID MG 24
aeronca65t A-Series Austin engine Other British Cars 0
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
Creatrixx A+ head on an A series engine? British Motor Corp 8
mjamgb Modern pistons for a 3-main B-series engine Racing 15
Sherlock BMW 3-Series [with Corvette engine!] Other Cars 5
coldplugs A series OHC engine British Motor Corp 5
AngliaGT Jeep J Series Pickups Spotted 0
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
Deanrobert Xke series lll cooling issues Jaguar 5
zoohow TR2/3/3A lights in series Triumph 2
LD-Ordie Series II gear lube question Rover / Land Rover 3
PAUL161 T-Series T Series Starters MG 0
PAUL161 T-Series T series tierod ends MG 2
O XKE series 2 thermo fan switch bung stud repair. Jaguar 9
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
L BMC A-series: Oil in coolant British Motor Corp 6
6 SOLD!! For sale 1966 Series 1 FHC $85,000.00 Jaguar Classifieds 3
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
N Wanted Spats - XK Series? Jaguar Classifieds 4
S Series 1/2 Wiper Motor Needed Rover / Land Rover 0
steveg HS vs HD series carbs Austin Healey 2
W XJ6 Series I bumper swap to Series II Jaguar 0
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
D Source for XJ6c Series ll Ignition key blanks & remote Jaguar 1
Lin Fairly new YouTube series on AH100 restoration Austin Healey 0
H Lotus Super 7 series 2 Race car for sale Lotus 0
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
steveg HD series Jet Centering - a Caution Austin Healey 19
M E-type series 1 plastic dash vents Jaguar 1
M XKE Coupe series 1 Tub versus series 1.5 Jaguar 1
O Wanted Vauxhall Victor F series parts Other British Classifieds 2
O TR6 TR series transmission compatibility Triumph 4
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
Basil About to re-install my fuel tank Series I E-Type Jaguar 6
Healey Nut "Father Brown" British television series Austin Healey 9
Basil Series 1 EType Spotted 2
J Wanted tri-SU carbs, manifold and linkage for '69 series 2 4.2 Jaguar Classifieds 3
Nunyas Salvaged Lotus Evora rebuild video series Lotus 8
D Series II E-Type tire size Jaguar 9
S M Series Bonnet Striker Pin failures TVR 2
