1275 Head to block dowel pins
64nailhead
I'm pretty new here so take it easy on me (first post).
I have acquired a 68 Sprite with a 1275cc that was disassembled when I inherited it. I'm in the process of putting it back together. I have a manual by Robert Bentley - The Complete 1275 Manual. I have a question about head to block dowel pins. Are there supposed to be any and in what holes do they go? Each of the holes that look like they could be the correct location are in the coolant porting of both the head and block. I would prefer not to guess and I would also prefer to have my head gasket seal correctly as well - lol.
Thanks in advance for any help you can provide!
No dowels.
I am not sure what the current preferred head gasket is. When I last installed one on a 1275 it was the Payen BK450 (composite gasket with a sealant on its surfaces).
That explains why I couldn't figure out where to put the dowels - lol.
It had a copper one in the box of old parts when I got, but I got a composite one in the Payen gasket kit I bought. I chose the composite as I've had very good luck getting them to seal in all other builds. Also, I had the heads and deck resurfaced, less than .010" each, so as to allow for a proper head seal. I intended to install the gasket dry, but is there a recommended sealer?
I should also mention that I have new studs and nuts as well - the old studs were horribly stretched.
Check specs for torque and tightening order. And the little studs for valve train only 25 lbs or so IIRC.
With the black composite gasket you don't use a sealer. With any of the copper gaskets (copper/copper or copper/something) I generally use spay copper on both sides (NAPA??) to aid in sealing the gasket.
I have never had an issue with the water or oil passages leaking.
Per Joe's comments, the composite gaskets go on dry. If you use the copper one, a sealer like KW Copper Coat works well. If you don't find KW Copper Coat in local parts stores, it is easily found on Amazon.
Welcome aboard -- I have a '69 Sprite. When my head gasket went kablooey, I used the Payen gasket. While you have the head off, you may want to have the blanking plug replaced with a threaded unit. I'll see if I can dig up the threat. It could potentially save you a lot of aggravation down the road.
Edit: Here's the post on the topic on the MG Experience: https://www.mgexp.com/phorum/read.php?1,2096990,page=1#utm_source=alias&utm_medium=mgexperience.net
I'm presuming by your handle that you are also a Buick aficionado?
The only time I had trouble with the blanking plug moving was due to sever overheating due to lack if coolant and me not having the brains to pull in at the Glen. My brain fade cost me an engine.
The plug moved due to the extreme overheating and a good machinist repaired. However I have never heard of the plug moving under normal driving conditions.
I would agree -- but if you ever have an overheating situation, why compound it by losing the head gasket as well?
Old thread and just getting this together. I had both the head and block resurfaced. The head was pressure tested with no issues. I'm going with it. Hopefully by the end if the month I'll be cranking this up.
T BMW K100 DOHC FI head on 1275 block Spridgets 7
bugedd 1275 Head Question Spridgets 8
B 1275 Head Identification Spridgets 5
L 1275 Head Gasket Spridgets 7
Boink Hardened/strong head studs on a 1275 - torque? Spridgets 5
Trevor Jessie 948 engine with a 1275 head question. Spridgets 3
T Milling a head on a Stock 1275 for compression? Spridgets 13
BugeyeNJ58 Cost to ship 1275 Cylinder Head? Spridgets 9
BugeyeNJ58 Head Torque Questions for 1275 Spridgets 1
F head bolts 1275 motor Spridgets 2
M 1275 Rebuild Question - Head Bolts Spridgets 6
regularman If a 1275 head had a crack in it. Spridgets 25
jvandyke head gasket 1098 vs 1275 Spridgets 1
regularman I need a 1275 head. Spridgets 12
pakiwi Head Off - 1275 - Recommendations Spridgets 19
T Rough budget +/- for 1275 cylinder head overhaul? Spridgets 10
Gray_Cat Looking for a 1275 Cylinder Head? Spridgets 0
E 1275 Cylinder Head Bypass Nipple Spridgets 4
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
dingleberry3343 1275 head gasket Spridgets 6
J 1275 Cyl Head volume question Spridgets 2
drooartz Smog head 1275 question Spridgets 33
cdsmith First time installing a head on a 1275 Spridgets 6
nathandarby67 Head swap for 1275 engine? MG 4
M 1275 Timing Cover Vent Spridgets 2
drooartz 1275 cruising RPM Spridgets 5
abarth69 Innocenti 1275 upgrade path Spridgets 1
D MG Midget 1275 rear oil seal. Spridgets 0
AngliaGT 1275 Engine Value? Spridgets 5
M 1275 Race Clutch Racing 5
drooartz Visual ID of a 1275 Spridgets 14
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Tuning up a 1275 Spridgets 17
B General MG 1275 Midget CamShaft Slot / Star drive to Oil Pump MG 2
BobHaskell Mini Cooper 1275 engine rebuild British Motor Corp 9
S 1275 oil pan removal Spridgets 30
M 1275 too high? Spridgets 2
R For Sale Fidanza Aluminum Flywheel for 1275 A-Series Spridgets Classified 0
Lin Checking static timing for a 1275 with Crane XR700 ignition Spridgets 0
Lin Fan belt for 1275 with alternator Spridgets 4
B Installing cam bearings 1275, can I do it? Spridgets 1
K 1275 Distributors Spridgets 6
T Dampner for a 1275 [damper? dampener?]: recommendations Spridgets 6
T Rebuilding a 1275 for a BE Spridgets 8
R 948 convert to 1275 info Spridgets 13
G Wanted ISO Gearbox for 69 Sprite, 1275 engine Spridgets Classified 2
