Head Torque Questions for 1275
BugeyeNJ58
Just read the excellent answers to head/rocker torque questions for 948. Are there many differences for a 1275, especially for a retorque?
Spridget64SC
Pretty much just the torque values. Follow the manual's pattern. I usually omit the retorque on the rocker assembly. Just don't see the need. I just do the 3/8" studs. Make sure to back off 1/8 to 1/4 turn and make a smooth steady pull. Then pull it down again just to make sure. Make sure the pressure is off the coolant system by venting the radiator cap. This ensures no pressure from the coolant system trying to push past the section of the head gasket you are re-torquing.
HTH, Mike Miller
I Head torque questions for 948 Spridgets 6
B Head Re-Torque Austin Healey 8
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
Kleykamp TR2/3/3A Head bolt torque??? Triumph 9
M Proper torque for cylinder head nuts Triumph 20
Boink Hardened/strong head studs on a 1275 - torque? Spridgets 5
dklawson GT6 Head Re-Torque - Mk1 GT6 Triumph 8
memphis Torque Head Bolts & Adjust Valves Austin Healey 13
K TR2/3/3A Re-torque my rebuilt TR-3 head Triumph 11
M TR4/4A tr4a torque specs for head? Triumph 1
G cyl head torque specs Spridgets 5
K TR2/3/3A Head bolt torque TR3 Triumph 3
KVH Head Re-Torque Triumph 18
J First oil change after rebuilt and head torque Spridgets 6
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
C cylinder head torque MG 33
T TR4/4A TR4 Cylinder Head Bolts Re-torque Triumph 4
Morris ARP Head studs torque... Spridgets 2
I Torque setting for BN1 Cylinder head Austin Healey 2
tahoe healey head torque Austin Healey 8
W TR5/TR250 Torque setting for TC2500 head Triumph 3
S Wedge proper torque for TR7 cylinder head Triumph 8
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
tahoe healey "Convertible" vs "Drop Head Coupe" Austin Healey 8
K TR2/3/3A head gasket repair wire Randall Triumph 1
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
