TR6 ZS 175 CD2 stuck air valve/piston
crash21
I have a stuck air valve piston.
The piston is stuck solid. I have tried using a long handled screw driver and prying the piston making sure not to gouge or mar the carb body, but no luck.
I have had it soaking in PB blaster for 2 days and tried some Seafoam "Deep Creep" with no luck. All together it has been soaking for 4 days.
I tapped lightly on the areas I can reach with a ratchet extension so as not to gouge the piston but no luck on that either. It hasn't budged.
Is there any trick or tip anyone can give to free the piston?
I have removed everything from the carb including the throttle shaft and plate.
I may have to get another carb if I can't free the piston.
Thank you for any and all advice/tips.
I'd try one of the chemical carb cleaners that are intended to soak the part, like Hydroseal or Berryman's Chem-Dip. A bit pricey but very effective. Looks like WalMart has a 3/4 gallon can of Chem-Dip for $20, but you may have to combine two of them to have enough to cover the carb. Don't let it soak too long, though, as the chemical may slowly attack the base metal as well. (I once ruined a OD solenoid bracket by forgetting it was in the Hydroseal bucket.)
Other tricks I've heard of are soaking in phosphoric acid solution (eg Coke, DX579 or Prep&Etch), or old brake fluid (DOT 3/4). Same story, let it soak but check frequently for surface damage.
But if it's that badly corroded, it may be junk anyway.
I always have a can of this for soaking carbs parts and other small stuff:
https://www.berrymanproducts.com/pr...rryman-chem-dip-carburetor-and-parts-cleaner/
I've gotten it at my local FLAPS (O'Reilly's). One can lasts a long time as you just lower the bits in a basket, whatever comes off sinks to the bottom of the can.
Only caution is to not leave the alloy parts in there too long - check them after a couple of hours.
Okay, Randall got there first.
Well, I soaked the carb in Berrymans Chem Dip for 2 days. Yes I know I am supposed to check it but at this point I just don't see it being usable even if I do get it freed up. No luck. it's still stuck solid. No movement whatsoever.
I see I can buy rebuilt carbs on Ebay for around $200.00 for a matched set. The master carb rebuild kit is 140 and I have already spent 40 bucks buying stuff to try to free up the piston on this one carb.
Http:// see this guy...Poolboy.
Cheers
Tush
Hegg Carburetor Detective Work 175 CD and 175 CD2 Triumph 3
Quackedo TR6 1969 TR6 Stromberg 175 CD-6 Triumph 1
P MGB Zenith 175 cd carb damper oil MG 2
H TR6 1974 tr6 stromberg 175 cd-2 choke Triumph 2
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
Pythias 175/70 13s. Pirelli! Spridgets 7
C TR6 ZS 175 What does this screw do? Triumph 2
B For Sale 175 CD Strombergs Triumph Classifieds 0
SherpaPilot TR6 Stromberg CD 175 Carb Tuning Triumph 8
aeronca65t BSA 175 Bantam British Motorbikes 2
J MGB Are 175 tires the widest that will fit onto a MGB?? MG 3
J TR4/4A 175 CD needle position? Triumph 5
L Stromberg 175 cd question Other British Cars 5
A Zenith 175 CD's Triumph 19
R Zenith Stromberg CD 175 float replacements? Triumph 3
M stromberg 175 cd? Triumph 5
M stromberg 175 choke cable? Triumph 2
M zenith stromberg 175 cd Triumph 24
M zenith stromberg 175 cd. Triumph 7
B where to buy 175/80r15's? Austin Healey 11
T Hap - 175/70/13 or 185/70/13 for your Superlights? Spridgets 26
ncbugeye Problem: Bugeye and 175/70 tyres on SuperLite rims Spridgets 1
mrv8q Couple ZS 175 questions Triumph 9
H Zenith Stromberg CD 175 Too rich Triumph 7
Brooklands Air Filter for Stromberg 175's Triumph 3
E Stromberg 175 idle Triumph 2
1 175/70/14 tires, yay or nay? MG 15
philman FREE ZS 175 Carburettors [front and rear] Triumph 2
J Zenith Stromburg 175 carburator tune? Other British Cars 3
J TR6 ZS 175 Mod. 3292 rebuild [70TR6] Triumph 2
R Zenith 175 CD Choke Triumph 0
H stromberg 175 carbs Jaguar 1
jerrybny TR6 73 TR6 ZS 175 CD-2 carb question Triumph 6
W What is the proper procedure for priming S.U.175's Triumph 4
A TR6 Stromberg CD2 Air Cleaner Covers Triumph 3
S TR6 CD2's Triumph 4
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
