Why is it missing now ?
bighealeysource
Bronze
Hey all,
Had to trace an electrical problem on my 100M when I completely lost power. Ended up being the white wire from the fuse box to the coil had come loose at the fuse box. Fixed that and started right back up. Of course in the meantime before I found that thought the Petronix module had given up the ghost as engine was turning over and pump was working. So, replaced the module with a new one I keep as a spare. When that did not work I went through the wiring and found that white wire mentioned above. Now that I have put the original module back in getting a miss at lower speeds, the intermittent type burbling - where I had none before and car was running perfect. The module only goes in one way, no adjustment, but I did not check the timing out as felt it would not have changed. Kinda stumped as have not touched the carbs or the timing but did take the module out and then put back in. Any advice on what to check or to do ?
Thanks,
Mike:confusion:
I've had one of the early Pertronix units in my BJ8, probably for close to 15 years. A couple years ago I bought a new one as a spare, but learned, to my dismay, that they have 'improved' the unit and the mounting has changed. Because of this I cannot just swap the spare in if the old one fails; if it fails on the road I'll have to put it in and set timing by trial-and-error (set for a decent idle, then be alert for ping and retard if necessary; hmmmmmm ... maybe I should throw the advance meter in the boot along with the thousand tools and hundreds of spare parts).
Doubt this is your problem--you probably would have noticed the differences in the units--but throwing it out there anyway.
bighealeysource
bighealeysource
Bronze
Hey Bob,
Thanks for getting back on this. Could be exactly the problem as the older petronix unit is over 10 years old. Going to just get out the timing light and makes sure that is right as "not gonna touch them carbs" as was running perfect before the electrical issue !
Regards
Mike
Ed_K
It could be the coil. Check primary side of the coil with all wires disconnected for 3 ohms.
If a lot more or less than three ohms, replace the coil.
But since the white wire came loose, it may have damaged the hall effect transistor
inside the petronix pickup before it came all the disconnected.
Or since you have restored full power to the igntion circut, the rotor is starting to
arc if you have one of the black plastic modern rotors that doesn't work very well.
Try one of Moss's red colored rotors.
bighealeysource
bighealeysource
Bronze
Hey all,
Thanks for all the hints on what to look for. Turned out to be very simple - dizzy was apparently not tightened down enough ( stupid on my part) so when I was taking the Petronix off and back on, managed to turn it enough to advance the timing way too much. Re-timed and runs like a charm. Had forgot how bloody small the timing "hole" on the pulley is and hard to find. But located it, remarked and good to go!!!
Regards
Mike
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
kurts100 Am I missing something? Triumph 8
