brake master missing seal
RestoreThemAll
Does anyone know where to source what Moss calls a dust seal (closest to the push rod). See attached. In the cat they mention that its discontinued and not needed. At the very least it must help align things.
Also, in the pic, the rebuild kit came with two large round gaskets. What are they for? Not for my BJ7?
Dale
vette
Dale, I presume you are talking about the dust boot that is at the inboard end of the master cylinder. #6 in my pic. this is just a dust cover to help to keep dust and dirt away from the two inner seals and cylinder. Without the boot you'll just know when the inner seals are leaking sooner. :smile:
If it is not available from the usually Healey suspects, you could try a place like Summit Racing and just by one that has a similar diameter. Also, why don't you give Healey Surgeons a call in Tacoma Park, Md. They have a terrific inventory.
R
RestoreThemAll
Hey Vette,
Yes, that's the seal. I don't care as much about it being a dust seal. I think that the cap will take care of dust, and I'll wipe my feet before I get in the car, or not. I have to think that seal works in conjunction with the inner seal to keep the whole thing straight in the cylinder. Otherwise it'll pivot on the inner seal slightly. Not a huge deal but with time will cause wear. I did have my original girling masters brass sleeved so it may not be as much of an issue.
I'll check with Summit and Surgeons. Thanks for the tips.
I'm working hard to get this thing restored in 10 days. On average I work on it every 10 days!
R
RestoreThemAll
Thanks BR. I'll check for size and fit. There's two in each kit. Strange.
steveg
That item #8 has been discontinued. That's why you don't see it included in the Moss drawing. There were some problems with it causing brake or clutch drag by moving the piston slightly forward.
PS - Pegasus Auto Racing is the source for genuine Girling masters and rebuild kits.
R
RestoreThemAll
Steve,
Did you leave out the seal on your car? Are you recommending that I leave it off? I would like to learn from others experiences. This forum has helped me to avoid plenty of potential pain.
Dale
steveg
Steve,
Dale
Dale - A few years ago I had a situation where a new master cylinder in effect made it as if I were riding the clutch all the time. I wore out a new clutch disc in a year. I believe this seal was causing the piston to be just a little forward of where it should be, which had the effect of preventing the clutch fluid from flowing back to the reservoir. As I recall that MC had the seal and when I removed it, the MC worked properly. It must have been an NOS MC to have had the seal. With the external boot over the end of the MC, the seal does absolutely nothing anyway. No o-ring is necessary to replace it.
R
RestoreThemAll
Thanks for taking the time to explain your experience Steve. I'll leave the seal off
... the effect of preventing the clutch fluid from flowing back to the reservoir ...
Hmmm ... not sure that's how it works (but, as usual, I could be mistaken). When you apply pressure to the pedal--brake or clutch--a small, spring-loaded seal at the forward end of the cylinder--sometimes called a 'foot valve'--closes the line to the reservoir (if it didn't, you'd push fluid back into the reservoir instead of to the slave cylinders). When you release the pedal, the piston retracts, the foot valve opens and fluid is drawn from the reservoir in order to 'refill' the M/C. Fluid should never be pushed into the reservoir; if this happens the foot valve has failed. In fact, the test for a failed foot valve is observing the fluid level in the reservoir and if it rises any at all when the pedal is depressed the foot valve is leaking (in effect, the foot valve is a one-way check valve). I got a lesson in this when the foot valve in my brake M/C was damaged somehow, and had to drive over a thousand miles having to pump the pedal a couple times every time I needed to brake.
This relates to the discussion on the Healeys mailing list about the small spring in the clutch master cylinder which can apply pressure to the graphite release bearing, causing premature wear to the bearing and/or the clutch disk. If fluid was allowed to return to the reservoir the pressure would be released, but you'd have other problems.
steveg
Bob - I think you're right and my reasoning was off a little. However I had a problem with the clutch being "ridden". Maybe it was a collapsed hose - I replaced it with an SS hose at the same time. That said, the factory removed that seal for a reason - maybe it was causing problems.
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
D BJ8 brake master cylinder question Austin Healey 6
D TR2/3/3A Brake Master Cylinder. Triumph 4
Michael Oritt Brake Master Cylinder access Austin Healey 0
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
vickxxx T-Series Brake master adaptor MG 2
M TR6 Brake master cylinder question. Triumph 2
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
T TR2/3/3A Girling Brake/Clutch Master Cylinder [slant port] Variations? Triumph 6
T TR2/3/3A another brake master cylinder question Triumph 16
M_Pied_Lourd TR2/3/3A Brake and Clutch Master Pushrod Question Triumph 4
T TR2/3/3A Aftermarket brake master cylinder 1961 TR 3A Triumph 11
S "59" 100-6 brake/ clutch master cylinder upgrade Austin Healey 3
H master cylinder brake vs mc clutch Austin Healey 14
PatGalvin TR2/3/3A Brake Master Cylinder Fluid Reservoir Bracket needed, TR3A Triumph 6
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
D MGA Master Brake Cylinder Leak MG 2
nevets question about brake master cylinder Austin Healey 12
Lukens More clutch / brake master cylinder questions. Triumph 7
L Initial Adjustment of Pushrod on BJ8 Brake Master Cylinder Austin Healey 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
Jim_Gruber Brake Master from Alternative Sources Spridgets 10
KVH Bleeding the Brake Master Cylinder Triumph 8
J TR6 TR-6 Brake Master Cylinder Seepage Triumph 4
J TR6 TR-6 Brake Master Cylinder-Rebuild or Replace ? Triumph 4
D Brake master cylinder Austin Healey 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
A Wedge 1980 TR7 Brake master Question Triumph 5
R TR2/3/3A TR 3a brake/clutch master cylinders/pedal movement Triumph 4
rlich8 TR4/4A TR4A Brake Master Connector Leak Triumph 2
A Divided brake master cylinder MG 6
1 Brake Master Cylinder Spridgets 11
K TR4/4A TR4A Master Brake Cyl Internal Spring Clip? Triumph 6
K TR4/4A TR4A Brake Master Cylinder Internal Spring and Triumph 13
E BE w/dual line brake master....90 degree fitting? Spridgets 12
E 1275 Brake Master Nylon Bushing Spridgets 3
letemglow Brake line layout with dual master cylinder MG 6
B Brake/Clutch Master Cyl. Spridgets 8
