MGB MGB missing and perhaps knocking under load
Jerry
Just finished putting the head back (valve job) on a friends MGB and when we went to start the car there was no spark at the plugs. The pertronix test as dead, the coil kept changing the resistance across the terminals. Coil is probably original. Anyway, replaced both, which require new timing since the new pertronix put the unit in a different spot on the plate versus the old unit. Got it started and it revs fine sitting in the garage. But driving it, there is a miss about 3000 rpm and perhaps some knocking. So I assume the timing is still off. Would you guess that it is acting like :
too much advance?
too retarded?
Anything else to check?
Jerry
Sarastro
The obvious thing to check is to hook up a timing light and see what's happening. Have you done that? If not, how did you set up the timing initially?
JPSmit
mixture? lean spot on the needle compounded by a slightly lean mixture to start? (and always check oil in the dashpots)
J
Jerry
I will check the oil in dashpots this am. I will also pull the spark plugs and look at color. Question on the Zenith carbs, how many flat of turn cause a big effect on changing the mixture?
Jerry
blueosprey90
Try checking the resistance on the spark plugs with an ohm meter. I had petronix wires, and when tested one was at 400,000 ohms, the others in the 25,000 to 50,000 ohm range. Got some cheap NAPA low resistance wired, but I'm not running a petronix distributor. Easy enough to test, though.
What is your advance at 3,000 rpm? Is it within spec?
I'm no expert, but I don't think timing would generally cause a miss unless it was way, way off, and them more of loss of power, a backfire or a definite misfire. A knock, to me, is something else, sort of what you get when too low octane in the fuel. If you hold the engine at idle at 3,000 rpm, does the engine run smooth, or can you see it start to shake?
EDIT: I meant, "check resistance on spark plug wires!]
JPSmit
Zenith carbs? Not SUs? Don't think you can adjust mixture on Zeniths?
J
Jerry
I did put an ohm meter on the wires and they were close on the readings. I have not read the timing at 3000 rpms yet. I will check that tomorrow, what advance should I expect? It is Zenith carbs and they can be adjusted. I made it a little richer and will try it in the morning. More info, we had problems with the rings no setting so we replaced them. Compression prior was only 100 psi, and now is 125 with only 40 miles on new rings. So the compression went up 25%, so I am thinking that it needs to be richer fuel???
Found a new question for you. The vacuum advance has a tube that goes to a unit over on the servo. What does that unit do? and it has two wires to the unit, does it matter how they are connected. I know they were disconnected when the engine was taken out.
Jerry
blueosprey90
I'm a MGA guy, so can't help too much. If you replaced the valve guides, a valve could be sticking as the guides heat up and expand. You might double check your valve lash. But a miss is probably ignition, unless can there be an air leak at the manifold. Listen with a tube. Finally, maybe it was always there and just wasn't noticed.
J
Jerry
Update: put it on a CO2 and carbon machine. CO2 says it wants more gas. We adjusted as much as possible but the smog part of the carb will not allow much. Needle is old, so examination showed a flat spot, sanded it down. Also checked the timing again with another timing meter and that did some adjustment. So car drives better, more power, minimal pinging, but that miss at 2500-2800 when running steady is still there. Must be ignition but the Pertronix is brand new, rotor, wires and plugs have 700 miles on them. Coil is new. (3ohm).
Car is a 1978 .
I called Pertronix and they suggested a lower Ohm coil which I had. The instructions say a 3 ohm for a 4 cylinder, but I put the 1.5 ohm on as per their instructions. No change. Then they had me test the coil under load.
volt meter positive to the positive side of the coil, and ground the negative side of the coil. 10.3 volts. passed that test. so according to Pertronix, it is not their unit that is the problem.
Still stumped.
Jerry
J
Jerry
Another update with a solution:
We changed out the distributor (45D) for a 25D that came from a running car. No more MISS. So the first distributor has a problem but I don't know what it is . At least we know how to solve it.
We can buy new 25D and 45 D distributors. I think the 45D just has limited advance curve for emissions control. Any of you know the difference?
Jerry
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
T MGB-GT cant rails on 1967 MGB GT MG 12
JohnGone Wanted '80 MGB without seat belts? MG Classifieds 3
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
JohnGone Wanted Spare & Jack for an '80 MGB MG Classifieds 0
B MGB 1977 MGB Battery Box and Shifter knob MG 4
