MGB Just bought a 1966 MGB
jjroth63
Member
Hi,
I have some questions:
What year is my car? The title says 1966, but who really knows what it is, the "VIN" is a mystery.
I bought a 1966 MGB (?) on 7/3/2023 from a guy near Indianapolis Indiana. He has only had the car for six months, be bought it from an auction in Maryland. I live near Chicago and I will pick the car up from him within the next week, I imagine the fun will begin then.
There is a new "VIN" tag in the engine bay and an engraving on the inside of the driver's fender, neither marking looks factory. The title and bill of sale both show the number on the new "Vin" tag, are there other markings that can help me verify the factory identification numbers. looking online, I think the number should start with: GHN3U and then a five digit serial number.
but this number is on the title:
CN141164
Can anyone help with my VIN search?
It looks like I have an alternator, can anyone confirm?
Neither door closes flush with the car, they both seem to latch, but not go flush. FRONT-3.jpgSIDE-DRIVERS-2.jpgSIDE-PASSENGER-1.jpgREAR-2.jpgENGINE-1.jpg2023-07-03 15.48.47-2.jpgENGINE-2.jpgINTERIOR-1.jpgINTERIOR-2.jpgDASH-1.jpg
Thanks,
John
J
jjroth63
Member
I am sorry, I don’t know what was modified, I do not have the car yet. I don’t know what was modified over the last 57 years
Mickey Richaud
Battery relocated to engine compartment (from beneath rear deck - originally [2] 6 volt batts). Alternator instead of generator. Weber downdraft carb, replacing dual SU's. Looks like a later model master brake cylinder. Later model wheels. Bumperettes removed. Someone else with a sharper eye may spot something.
PAUL161
I'll reserve my opinion on this car. There are too many questionable things about it, the scratched in serial number ??? Hope you don't have difficulties registering it.
Platinum
Distributor cap is a later one, no idea about the dizzy itself. Oil filter has been changed to a "screw-on" cannister type. Upper heater control knob is "strange", the switch for headlights and the windshield washer pump are different, the blank hole for the overdrive switch has an odd "cover" on it.
Joe Reed
Push button exterior door handles replaced pull handles mid-year 1965. Reverse lamps were a mid-year 1967 addition. That means your car likely IS a 1966, although it could possibly be a late '65 or early '67. So much has been changed it's hard to nail it down exactly since you don't know what else might have been done to the car over the last half century.
Other obvious changes: the front turn signal/parking light lenses would have originally been clear/white - a common change since I believe the original color was unavailable at one time....and some owners also changed them out to amber anyway. The steering wheel is obviously aftermarket and the seats have been reupholstered in a non-original style.
J
jjroth63
Member
After my research of the VIN and the undisclosed photos (of rust damage) from the auction site where the seller bought the car, I was advised to pass on this car. It looks like I am back on the 1966 MGB hunt. I requested my deposit be returned to me and he sent the funds.
I do not know what the seller will do with a car with a "fake" VIN.
Hopefully I will post another car soon.
Thanks for everyone's help, advice and good wishes.
John
PAUL161
Good news on the seller refunding your money! (y) Wise move on your part on backing out of the deal. I think you will be a little more reserved about shelling out monies until you know for sure what your buying! There is a lot of nice MGBs out there, just use a little more caution. PJ
Platinum
Good you got the funds returned. The '66~'67 MGB was the pinnacle for the cars, after that the pollution regulations emasculated the cars slowly over time. Pre-1965~6 the three main bearing engines weren't as stout as the five main units. Engine tag numbers should start with "18GB-xxxx" for the five-main (if a tag exists). The instruments and switches didn't change until 1967, when the washer fluid pump and headlight switch were swapped.
These shots are of our '65, something to use as visual reference & information. The center console is one I constructed, but the switches in the dash itself are as original from '62 to '66. Steering wheel is from the commemorative "MGB-GT Special" in later production, so not original. Driver's seat is a Recaro racing shell replacement, passenger seat is a later one with headrest. Radio is a concession to modernity.
CARSINC
Hi,
CN141164
Neither door closes flush with the car, they both seem to latch, but not go flush.View attachment 90426View attachment 90427View attachment 90428View attachment 90429View attachment 90430View attachment 90431View attachment 90432View attachment 90433View attachment 90434View attachment 90435
Thanks,
John
Bugeyes and Sprites were marked in crayon under the hood and behind the dash. The number inside the driver side fender is not the vin. Vin tags in the engine bay were held on with screws. Check with the Bugeye Guy, he may know.
Platinum
Nice heal toe converted accelerator pedal. Is that a Paddy H. unit?
Yes it is, D. Good eye! They were a "hen's tooth" for a while, but I understand someone has started offering them again. This one has been with me since about 1969, the steering wheel and factory hardtop as well. All have been on three of my cars over the decades.
Grantura_MKI
Mine still has the banjo wheel. It’s pretty much as it came, with the exception of a front anti roll bar fitted.
Had a hard top, but sold it on many years ago.
Had a wood wheel on my last MGC GT.
AngliaGT
Almost everyone knows that the '67's were best (because I own one).
You need to trade me that steering wheel,as (I believe) I have a "Special",
but no Special steering wheel.
Platinum
Sorry, Doug. After nearly fifty-five years with it, I'll quote a Hollywood actor: "...from my cold, dead hand!" :p
AngliaGT
Then remember me in your Will.
Let's make a deal - I'll go to your funeral
if you'll go to mine.
Platinum
I'll be there in spirit...
Rob Glasgow Why I bought my Healey Austin Healey 6
maxwedge5281 bought back my first nasty boy conversion!! Austin Healey 6
Editor_Reid Bought Another One Austin Healey 14
TomMull TR2/3/3A Tropical fan, I wonder what I bought?? Triumph 2
D You Tube made me do it. I bought a Milwaukee dry cut saw. Restoration & Tools 6
glemon The E I almost bought Jaguar 10
D TR2/3/3A Help! What have I bought? Triumph 47
I What healey have I bought..? Austin Healey 17
69MGC MGC Just bought an MGC! MG 13
Marla TR4/4A Just bought a 1964 Triumph 23
S TR6 Canuck bought a TR6 Triumph 8
L Bought our first British car Other British Cars 28
N TR6 just bought a 74 TR6 with over drive..which size tires would be best Triumph 6
RickB MGB Bought 1980 MGB and got it home - head gasket? MG 15
T TR4/4A Yeah, I kind of bought another TR4. I wasn't looking - honest. Triumph 43
AngliaGT Bought a '74 Midget Spridgets 16
J Found an E Type in a Barn. Bought it. Let's Make it Run Jaguar 15
justin_mercier Wedge I guess I'm a glutton for punishment! Just bought another TR7 Triumph 9
3798j General TR Correctly Bought Triumph 15
J Went To Auburn Cruise Night and met an Aussie who just bought a 54 to take back home. Austin Healey 1
J Just bought a 1968 Austin Mini British Motor Corp 22
W Bought a used center console a while back..... Spridgets 6
Marvin Gruber MGA Pulled the trigger. Bought a MGA Twin Cam MG 12
H TR6 Sold the Healey 3000, bought a TR6 Triumph 16
Glen_B Bought the Mini Spridgets 6
G Spitfire Bought a Spit today, a bit bummed out Triumph 12
JPSmit Bought a Tool Chest today - thoughts needed. Restoration & Tools 16
drooartz Now I've done it, bought a FJ40 Land Cruiser Other Cars 9
RickAnderson MGB Just Bought An MGB Project! MG 7
AngliaGT Just bought #10 - What Have i Done? Other British Cars 7
CZ_Dave Sick, Addicted, Twisted, Just bought # 10 MG 13
longbridgehealey bought a 69 Sprite, gotta horn question Spridgets 11
Darrell_Walker Bought a car Triumph 56
jlaird Found and bought Spridgets 28
GBRandy I bought a red one Triumph 69
78Z Bought a Lada Niva! Other Cars 7
jvandyke I bought a Fiat X1/9....I think Other Cars 33
PATR8 Bought 15 inch rims for my 8 Triumph 3
G I bought the wrong oil pump Spridgets 5
S I just bought ARP main stud kit 206-5405 Austin Healey 4
toysrrus TR2/3/3A "I`ll be back soon"!! Bought a `57 TR3 finally!! Triumph 12
T Just bought a 1997 Xj6 L Jaguar 1
T Bought a full sized electric oven for .99c on eBay Spridgets 7
T Bought a car at the supermarket today... Triumph 6
Jer you never know... I just bought a Bug Eye ! Spridgets 21
TRMark Bought a T140E British Motorbikes 10
RickB I just bought a MK I Midget Spridgets 13
E Hey! I'm a new member that just bought a triumph. Triumph 25
Tullamore I bought a Roller Other British Cars 21
PATR8 almost bought a Volvo today, need diagnosis help Other Cars 8
