MGA Missing under load
Simmo
Totally rebuilt MGA 1500.
I figured when I put the engine back in I had done the timing correctly as it idles just fine at around
600 RPM.
Now, when driving, I find that there is a lack of power and missing at around 2500 RPM under normal flat driving load.
It has a woodpecker fuel pump which I would immediately suspect but then again its only a 1500 engine.
What are your thoughts which would be very much appreciated.
JPSmit
My very first inclination would be to check the dashpots - either no oil or the wrong (to light?) oil
PAUL161
Very possible a fuel issue, but make sure the distributor mechanical advance is functioning properly and no wobble on the shaft. PJ
Bob Branson
Member
Dashpots usually cause spitting back rather than missing. I vote for the distributor. Also remember, if your A has the original style plug wires, they're carbon, and prone to breaking.
J MGB MGB missing and perhaps knocking under load MG 10
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
F Missing and hesitation, only after a hot start Austin Healey 6
kurts100 Am I missing something? Triumph 8
