Missing and hesitation, only after a hot start
Fairview
I hope you don't get tired of hearing from me, but I've put 300 miles on my 3000 in less than a week, so finding plenty to ask about.
Here's a mystery I can't solve: My engine runs smoothly and with no issues unless I have parked it for a few minutes while it's good and warm.
From a hot start (where the temp gauge has climbed over 190 degrees from just sitting, with the engine shut off) it will miss and pop. I am able to drive it, but it is missing quite noticeably, not an even miss like a fouled plug, but an unpredictable miss. It seems to stay that way until it cools down, or I shut it off and leave it.
Next time, after the engine is cold, starts up, runs beautifully, I could go 100 miles without issues. Then if I park for a while, engine compartment gets hot from just sitting there, then it misses again.
Any ideas? Thanks very much, Jeff
Here's an unrelated photo, so my post doesn't look so boring!
BoyRacer
What creates this problem is that the intake manifold and exhaust manifold are bolted together. Another good reason for putting headers on your Healey.
F
Fairview
nevets said:
possibly a bad coil
I wanted to report back that yes indeed- a bad coil. To recap, my 3000 would run beautifully until it got good and warm, then miss unpredictably, still driveable but a very noticeable miss. I had avoided replacing the coil as I'd never had a bad coil in all my old car years, so doubted that as the cause- shows I was wrong.
I put on a new coil and it now revs smoothly even when warm. In my research, it was suggested that an oil-filled coil should not be mounted horizontally as it is more prone to going bad due to the oil not covering all the innards! I don't know if that is true or not, but I thought I'd mention it. Of course I put mine right back where it was atop the generator.
Anyway, Nevets, you were on the mark. Many thanks, Jeff
homebeforedark
From my experience about ten good coils are replaced for one bad one. Same with bulbs . I always suspect something else but every once in a while a bulb actually burns out.
GTP1960 TR2/3/3A hesitation and missing between 2000 & 3000 rpm Triumph 3
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
P TR2/3/3A 1958 TR3A missing on cyls 2 & 3 Triumph 8
K Missing spring clutch release lever Other British Classifieds 1
Rob Glasgow Missing Graphite Electrode Austin Healey 16
Bayless Missing important part Spridgets 0
bighealeysource Wanted Looking for missing BN2 door and cockpit moldings Austin Healey Classifieds 0
Jim_Gruber Missing Bugsy IV / Transporting a BE on a U-Haul Car Carrier Spridgets 18
warwick-steve Missing grease cap in front hub Austin Healey 8
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
P TR2/3/3A Convertible Top Frame Missing Hood stick advice needed. Triumph 4
T TR2/3/3A Missing bush Triumph 4
G Brake fluid missing Austin Healey 6
R brake master missing seal Austin Healey 11
P TR2/3/3A Missing rear seat back rest/bulkhead. Triumph 7
KVH TR4/4A I Can't Stop Burning Oil; Engine Missing at Take Off Triumph 5
Simmo MGA Missing under load MG 3
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
S TR4/4A Exhaust manifold missing stud Triumph 8
P Is my shifter bushing missing? Austin Healey 25
J Help with 61 AH Sprite missing parts. Spridgets 3
tomshobby Shift knob insert is missing Spridgets 12
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
richie TR4/4A Missing since rebuild with Pertronix Triumph 9
B Installing New Leaf Springs on 100-6 - Am I missing something obvious? Austin Healey 19
bighealeysource Why is it missing now ? Austin Healey 4
RedTR3 TR2/3/3A Periods of Intermittent Missing Triumph 34
6TTR3A TR2/3/3A MIssing Zerk fitting? Triumph 7
bighealeysource Can't figure out why engine is missing on BN2 Austin Healey 6
J MGB MGB missing and perhaps knocking under load MG 10
angelfj1 TR2/3/3A HELP! Need quick fix for missing bonnet hinge pin. Triumph 5
Boggsy64 MGB King Pins appear fine am I missing something? MG 3
PHerder Door Parts missing :[ Need to beg, buy or steal... Spridgets 0
PAUL161 MGB Strange Reminder of a Missing Friend. MG 4
Parker MGB Headlights won't work after full repaint/restoration... what am I missing? MG 6
S MGB Radiator cap missing MG 1
P New tires, missing spoke Triumph 4
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
mgbmedic Wire Wheel Conversion - What am I Missing? Triumph 11
S TR2/3/3A missing problem with this tr3 Triumph 10
bighealeysource BN2 missing on acceleration Austin Healey 11
H Missing Oil Filter Spring Plate Austin Healey 2
M Missing zerks Triumph 10
judow Is a Registry missing??? Austin Healey 12
jsfbond Missing Plate Triumph 1
E How to identify Healey carbs, Tag missing Austin Healey 1
P Missing grille bar Triumph 3
M Missing at the Olympics Triumph 3
RAC68 The Missing Brake Fluid Mystery Depends Austin Healey 11
kurts100 Am I missing something? Triumph 8
